Author Topic: CB750 K5 Oil Pump wear  (Read 143 times)
Offline martin_uk
« on: November 23, 2026, 08:54:10 PM »
Continuing to assist my friend with his bike.
Have fitted new pistons and rings and overhauled head.
Precautionary check of oil pump revealed considerable marking of rotor tips.
More than I would feel acceptable, even though well under within the 13 thou max clearance.
There are used ones on Ebay, but risk finding similar issues.
I can remember buying more than one to find a good one.
As far as I am aware the internal rotors and outers are not available?
Any suggestions or sources appreciated.
Many thanks
1977 CB750F1
1978 CB750F1
1975 CB500K1
Triumph Street Triple 675R
Ducati 800 Icon Scrambler
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Re: CB750 K5 Oil Pump wear
« Reply #1 on: November 23, 2026, 08:58:00 PM »
At some point there was a member on the US site doing something with rotors, may be worth asking there
Offline martin_uk
« Reply #2 on: November 23, 2026, 09:28:24 PM »
Thanks Bryan
1977 CB750F1
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
« Reply #3 on: November 23, 2026, 10:17:43 PM »
We used to buy new gerotor from a supplier in Italy. I've just had a look and I can't find his site any longer but if he doesn't made them any longer the chances are someone else does.
« Last Edit: November 23, 2026, 10:23:17 PM by Nurse Julie »
Offline martin_uk
« Reply #4 on: Today at 09:33:26 AM »
Thanks Julie.
I have a message from  US forum, member in Germany, about possible source.
Will update for others when I hear more.
1977 CB750F1
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
« Reply #5 on: Today at 09:53:59 AM »
This makes me wonder about the ultimate cause of the wear experienced on the pump parts.
Are the cam lobes and followers OK?  or do they show signs of wear  ? Significant loss the will likely have passed through the pump head.
Offline martin_uk
« Reply #6 on: Today at 10:18:29 AM »
Camshaft , bearings and rockers fine.
The scavenge pump is picking up unfiltered oil albeit through strainer, so may be more susceptible to damage if oil contaminated
1977 CB750F1
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
« Reply #7 on: Today at 10:22:01 AM »
There's no effective filtration between scavenging pump head and main pressure side though. It goes through both, one after the other.
Offline martin_uk
« Reply #8 on: Today at 11:29:32 AM »
1977 CB750F1
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
« Reply #9 on: Today at 01:58:24 PM »
It does look like some chunky bits have gone through there, and more like gearbox "shrapnel"  at the size of those markings.
At that size they should have been captured by the filter at least.
I can't get a really good focus on them to see properly fine the detail though.
