Author Topic: CB750 K5 Oil Pump wear  (Read 299 times)
Re: CB750 K5 Oil Pump wear
« Reply #15 on: Today at 09:16:24 AM »
I agree that there's spare capacity in pumped lubrication (martin states the wear is within tolerance too) in effect to have the oil delivery not really compromised, as it is. The scavenge side, particularly, is always above demand as it has to keep sump empty over and above delivery rate on dry sump system by design.
Anything passing through the scavenging side of pump is though just going to go through the pressure side too, having no filtration in between the two section.
At least it's easy to remove and replace pump component in situ if parts cannot be immediately sourced.
« Reply #16 on: Today at 09:59:23 AM »
I tried experimenting with a chain of strong magnets on the outside of a cannister oil filter. Just to see if it captured stuff. I cut the filter in half next time I changed it and yes it did. Not a massive amount but any stuck there isn't going back into the engine. I just swap the magnets over when I change the filter. Shame the oil filter holder is alloy on the SOHC bikes. You could try gluing them to the inside of the filter housing I suppose. They are quite thin and a bit like a Victory V lozenge, really powerful though.
It's more the routine in automatic transmission. Primarily from steel clutch plate etc, there's expected % wear accumulation over lifetime to mitigate. Similar to yours in choice Ken, lozenge type magnet inside steel sump pan.
Working on a ZF 5 speed recently, patchy service history, oiled for "life" by manufacturer. A failure of radial orientation thrust bearing allowed one multiple clutch pack section to float too far, resulting in cut oil seal that held the oil pressure to activate the clutches. That bearing is undersized on all of this gearbox type and so ultimately fails in most example.
The sump though, having six of those little magnet, each of them with a very fine and fuzzy coating of ferrous material and showed the effectiveness of capturing small wear particles expected in use. It had completed more than 140k miles though, at over 20 years old too, well out of warranty and predicted service norm.
Apart from that bearing failure (they made it larger on next design) there was no discernable wear to other components.  Remarkably clean in there too, running obviously a pump and what turned out to be it's original filter (date coded) for entire life.
The magnet's accumulation showed how effective they are in this case. It was very fine though. I tried to measure some and came to less than 10 microns. 800 grit carborundum abrasive sized is in approx 8~10 micron range though. This should pass through a conventional oil filter and also through transmission pump, plus high pressure valuing etc. Very simple and effect control though to capture the bits.
Offline martin_uk
« Reply #17 on: Today at 11:18:07 AM »
Some interesting info from US site.
        That one looks like water-in-oil damage, from sitting with old used oil aboard. It will probably work OK with proper 20w50 oil, though. Use of lighter oil will yield low oil PSI when hot, just from the rotors. If you can get it (and have to use this pump) I'd suggest adding some more ZDDP to the oil in use as it will make the oil cling better to the wetted parts and increase suction a little bit. I've used that tack to support riders who couldn't afford to rebuild everything, but rode occasionally, with pumps like that one.
    Stats please.
    How many pumps last ten years?
    How many like this?
Four like this that I remember offhand (for other reasons) in the last 10 years or so: one is a show bike (seldom ridden at all), one is in California, one is in Arkansas and one in Texas. All the riders are older than me, so the bikes don't get ridden as much as they get polished, none are toured. One (in Arkansas) gets 40w oil in winter riding and 50w oil in summertime, he says that helps "keep the light off" for the Saturday-night visits to the local gathering place.
The rotors that cause the most problems are those that are scored. They often can't prime once they are fully drained, or even after the pump's removed and reinstalled. While smearing grease or Vaseline (same thing?) on them before reassembly will help prime a dry engine, it won't help raise oil PSI for very long as it melts away into the oil in a couple of minutes. I've seen this "magic fix" on the Internet several times this past year. :(
I've got 10 pumps on hand that are going to be rebuilt with 'kits' shortly, then offered here (with exchange), at least the ones that will prime with just hand-speed turning of the rotor. Three of them have similar damage to the one shown here (but not nearly as bad nor deep) and I have seen others like it in engines I've rebuilt that worked quite well, even with 15w40 oil self-priming them from fully dry (and no Vaseline). :)
https://forums.sohc4.net/index.php/topic,207459.0.html
1977 CB750F1
1978 CB750F1
1975 CB500K1
Triumph Street Triple 675R
Ducati 800 Icon Scrambler
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Offline martin_uk
« Reply #18 on: Today at 11:19:18 AM »
(Attachment Link)
Is that the pressure side of the pump or the scavenge side? The pressure side is fed from the oil tank, so not much chance of chunks from there. If it's the scavenge side, it's not really a concern.
I believe its scavenge, interesting point.
1977 CB750F1
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
