Author Topic: Getting started/project CB350/400f  (Read 8722 times)
Offline johndregg
« on: January 27, 2011, 09:10:40 AM »
I've inherited a basket case CB350four. Its been fitted with a CB400 four engine at some point in its life and has been caf
1960 Lambretta Li225
1959 Lambretta Li230cc
1964 Lambretta Li190cc
1975 Honda CB350 four
1996 Honda VFR750f
a busted mini and a rusty mercedes.
Re: Getting started/project CB350/400f
« Reply #1 on: January 27, 2011, 09:24:49 AM »
Hi John.
I assume that you have a manual? Manuals? (you can never have too many) - we have pdfs if required.
Also, put your location in your profile as it will save all the "Where are you?" posts and you may find someone close!
Steve
Offline johndregg
« Reply #2 on: January 27, 2011, 09:30:17 AM »
I have no manuals, PDFs are more than welcome!
1996 Honda VFR750f
« Reply #3 on: January 29, 2011, 02:37:47 PM »
Whilst the exhaust is off and the engine cold make sure the cam chain tensioner is working
Offline johndregg
« Reply #4 on: January 29, 2011, 05:21:54 PM »
ok, check the chain tensioner! duly noted. ;D
Is there a mark on the cam indicating which position it should be in when attaching the sprocket? I gather that pistons 1+4 need to be at TDC but the cam?
« Last Edit: January 29, 2011, 05:24:41 PM by johndregg »
1996 Honda VFR750f
« Reply #5 on: January 30, 2011, 09:15:13 AM »
You defo need a manual John...
I'll sort through my pdfs for a 350/400 book (most of mine are 500/550)   8)
« Reply #6 on: January 30, 2011, 10:21:03 AM »
Sorry - not a 350/400 pdf in sight...
However, if you go to www.honda4fun.com they have them all there - pick and chose!
Go to "Materiale" and "Parts Lists" and "Manuali"
Steve
Offline johndregg
« Reply #7 on: January 30, 2011, 10:45:04 AM »
Thanks mate.
1996 Honda VFR750f
Offline johndregg
« Reply #8 on: February 09, 2011, 11:08:28 AM »
Quote
Right i've had a look at this. Its the bolt down by the oil filter housing? I think mines been bodged. The adjusting bolt itself is ok but there is no lock nut, just an oversized nut spinning freely. I have to have another look at it, but i'm pretty sure someone has just ignored this for a lot of years.
Anyone got a pic of what parts should be there?
Progress made: New exhaust valves ground in and fitted.
                     NOS gasket set sourced and bought.
Going to try fitting the head tonight.
« Last Edit: February 09, 2011, 11:14:35 AM by johndregg »
1996 Honda VFR750f
« Reply #9 on: February 10, 2011, 06:43:00 AM »
DONT PUT THE HEAD ON YET if the rensioner is fubared its a bottom end strip to put it right and the engine is a lot lighter with the top off!!
Offline johndregg
« Reply #10 on: February 10, 2011, 08:47:49 AM »
I investigated it last night. What i thought was a bodge was just a loosened off tensioner. When i had a closer look it had the correct lock nut, but the thread for this was covered in road filth, i cleaned it all up fitted the blades and screwed it back in. I believe the tensioner is working.
The manual is terrible about this though, is there a better online resource for tips and tricks with photos?
1996 Honda VFR750f
« Reply #11 on: February 10, 2011, 08:57:47 AM »
Have you tried www.sohc4.net?
Go to http://forums.sohc4.net and type "350 cam chain tensioner rebuild" (or similar) into the search box.
There's strength in depth over there.
