Author Topic: Clutch cover  (Read 4299 times)
Offline judodave
Clutch cover
« on: February 09, 2011, 08:32:48 PM »
Hi, I have a new clutch outer cover to put on my 650z and I know it has a gasket between the cover and engine. Would I need to put a sealant on the gasket or can it go on dry. regards Dave
Re: Clutch cover
« Reply #1 on: February 10, 2011, 06:54:41 AM »
Clean grease to make the paper supple NO SEALANT
Offline judodave
Re: Clutch cover
« Reply #2 on: February 11, 2011, 09:25:03 PM »
many thanks
Re: Clutch cover
« Reply #3 on: June 04, 2011, 09:36:30 AM »
What happens if you do put sealant on? Is it just a risk of gunge getting into the engine?
...and is there a rule of thumb as to areas that do require gasket sealant?
Re: Clutch cover
« Reply #4 on: June 06, 2011, 07:16:49 AM »
Main risk is sealant in engine, think about it if you can see it outside at least the same amount is inside.
Sealant only on metal to metal surfaces and then SPARINGLY,
grease on all paper gaskets BUT NOTHING ON THE HEAD GASKET
