CB750
Redamping ND clocks
Topic: Redamping ND clocks (Read 3687 times)
HondaFour
Redamping ND clocks
March 16, 2011, 07:12:46 PM »
Can ayone tell me what damping fluid I need to restore smooth movement of my needles. The clocks are both NOS but it looks like the dampers have dried out inside. At medium speeds the needles fluctuate back and forth although the cables are both lubed and new. I can get them open no problem but can anyone tell me the lube points and how to fill the damper again.
SteveD CB500K0
Administrator
Ride on the Steel Breeze...
Re: Redamping ND clocks
March 17, 2011, 07:34:21 AM »
Ash has written about this in the past:
http://www.sohc.co.uk/index.php?topic=3154.0
AshimotoK0
Mad Scientist.... more power Igor ! Ù©(̾à¹Ì®Ì®ÌƒÌ¾à¹ÌƒÌ¾)Û¶
March 17, 2011, 07:25:11 PM »
I have 750cc
of silicone oil - you are welcome to a bit for 'nowt' if you send me the postage to try out.
PM if interested
Ash
“Alright friends, you have seen the heavy groups, now you will see morning maniac music. Believe me, yeah. It’s a new dawn.†Grace Slick, Woodstock '69 .. In the year of the Sandcast.
HondaFour
March 17, 2011, 08:14:54 PM »
Hello Ash
That would be great. Have you actually used the fluid with good results and do you know anywhere with pictures on a how to basis?
Cheers, Hubert
AshimotoK0
March 17, 2011, 09:58:28 PM »
No not tried it yet but the viscosity looks about right and according to another member not too critical. I have loads of old clocks here to try it on (about 30 in fact) the problem is having the time to experiment on it.
Also see this post:
http://forums.sohc4.net/index.php?topic=78890.0
Ash
Last Edit: March 17, 2011, 10:00:37 PM by AshimotoK0
CB750
Redamping ND clocks
