CB350/400
crank shells
Topic: crank shells (Read 5331 times)
steven400/4
SOHC Expert
crank shells
April 06, 2011, 07:45:38 PM »
does anyone know where the numbers or letters are on the top engine case to tell what colour shells i need i car,nt see them anywhere?
cb400f2 x7
honda ss 50
gsx 1400
neilma
Newbie
Re: crank shells
April 06, 2011, 08:48:32 PM »
As far as I can remember, they arent on a 400/4. The only way is to measure the gaps with plastiguage then work out if its within spec. If not, then you get the coloured shells to make up or reduce the gaps.
ttr400
SOHC Associate
Re: crank shells
April 09, 2011, 03:41:41 PM »
On the 400F there are markings on the rear of the crankcase, however I have never had luck with these codes. I mic the casings and the crank journals and choose the colour of the shells from the book.
Kevin
If you are addicted to the little CB400F then you might want to check out my website.
www.ttr400.com
steven400/4
SOHC Expert
Re: crank shells
April 13, 2011, 06:02:12 PM »
all done now i can find all the letter,s and numbers on the cases crank and conrods
thanks
cb400f2 x7
honda ss 50
gsx 1400
CB350/400
crank shells
