Author Topic: Hondamatic CB750A  (Read 4937 times)
Offline cavell
Hondamatic CB750A
« on: April 16, 2011, 05:32:10 PM »
Hi everyone I'm new here, I've been interested in these bikes for a while, particularly in a project.
Does anyone know anything about the Hondamatic CB750A? How they ride compared to the manual version, just how automatic is the hondamatic is?
With the reduced bhp (at 47) what kind of MPG do you get?
How they perform? Any problems with them? Any maintenance issues?
Any info would be appreciated.
Offline kaceyk2
Re: Hondamatic CB750A
« Reply #1 on: April 16, 2011, 07:40:51 PM »
Quoting from Pete Shoemarks book........
"1976 model frame number cb750A 7000000 onwards.
1977 model frame no.cb750A   7100000 onwards and
1978 model, frame no. cb750A 7200000 onwards.
The cb750A was a radical departure from orthodox motorcycle design, being one of a very small number of machines to offer automatic transmission in place of the conventional foot change arrangement. The engine itself was generally similar to the other cb750 models, but all transmission componants were unique to the cb750A.
The conventional multi plate wet clutch was replaced by an automatic type torque converter , oil was fed to the converter from the duplex oil pump, via a regulator valve unit.
Two drive ratios were available, each comprising a pair of gears working in conjunction with two independent , hydraulically operated clutches.
A foot selector pedal allowed the rider to engage neutral, low or drive as required. these being indicated on the instrument panel by lamps marked 'neutral','1' and '2' in the case of the later models, or 'neutral' 'L' and 'D' in the case of the 76-77 version.
An interlock arrangement ensured that the machine was in neutral whenever the sidestand was in use to prevent the machines unexpected departure under the effects of automatic transmission "creep".
A parking brake, operated by a cable terminating in a knob similar to those used on choke controls, allowed the machine to be parked safely on hills or to hold the machine against its tendency to creep at junctions...
In use, the machine was. as could be expected, easy to ride, the low ratio being particularly usefull in town or in hilly country, The cb750 A found a limited market, however, and the majority of riders found it to be at odds with their concept of what a motorcycle should be.
An evaluation model was sent to the UK , but after the market had been tested with the 400cc twin automatic, it was felt that the larger model had no market on this side of the Atlantic."
I guess folks that ride bikes prefer to see a clutch lever on the left hand side of their handlebars?
The 78 model weighed in at a hefty 540LB as opposed to the K7's 508 Lb and the F1's  499LB curb weight.
Taking comfort in not owing China 75 Trillion Dollars.
Offline totty
« Reply #2 on: April 17, 2011, 07:41:50 PM »
I've only ridden my dads 400 twin Hondamatic, but the basic principle is the same. (I've also got most of one in bits). You get 2 gears which you select manually, and torque converter instead of a clutch and a detuned motor with a very broad spread of torque. (Apparently the 400 shares head and carbs with a 250) In high the 400 is sluggish off the mark but picks up a bit by 20mph, it's far from quick but you can keep up with traffic without using low.
