Author Topic: Bit dim  (Read 6575 times)
Offline PatM
Bit dim
« on: April 24, 2011, 10:01:13 PM »
I took my bike for its first night-ride this evening- Id changed the headlight back to the original last year and not ventured out on it since Jan 11. I was on my way back from Swanley and noticed what I thought was a filament problem- the light kept on flickering in front of me, if you see what I mean- Headlight- or main beam was fine- but when I got back to Maidstone- I could rev the 400 and the headlight dimmed- any ideas? before I start replacing things willy-nilly! are they fed by a differnt fuse line? (I had my fusebox burn out last year leaving me stranded- but replaced it with one from Neil off Ebay)
Rgds
PatM
Re: Bit dim
« Reply #1 on: April 25, 2011, 04:33:26 PM »
Sounds like either a bad connection or the regulator box is sticking
Offline PatM
Re: Bit dim
« Reply #2 on: April 25, 2011, 05:00:26 PM »
The regulator was dismatled as I suspected it was the culprit- but it all belled-out and the shut isnt o/c as its getting hot. the coil also isnt pulling in- not sure what voltage its supposed to operate at? The earth was not exactly tight at the battery- but it is now..
Ive got about 11.5 v at the white wire- that feeds the main-beam. Should I be looking for 12?
Re: Bit dim
« Reply #3 on: April 25, 2011, 06:28:18 PM »
Depends on the battery voltage, anything over a 0.25 volt drop is too much
Offline Yoshi823
  • Biker to the bone...
Re: Bit dim
« Reply #4 on: May 04, 2011, 10:42:39 AM »
Hi Mike. The white wire feeds the low beam that's connected via the black regulated +12v wire that is connected to the red wire via the ignition switch.
If you wanted the regulator tested I have the test equipment to be able to set it up. I'm only in Bexleyheath but if you're going down to the VJMC on Thursday evening I could talk to you about it there.
Bikes...they're in the blood.
Yamaha R1 2001
Yamaha FZR1000R EXUP 1990
KTM 450 EXC RFS 2004
Honda XR400R 1997
Honda CB125T2 1980
Yamaha FJ1200 3XW 1991
Offline PatM
Re: Bit dim
« Reply #5 on: April 25, 2017, 07:06:18 AM »
Nothing like answering your own old post- This was a knackered battery- once replaced, all problems disappeared- the 35w light singling brightly like a candle in the w........
i was foxed as the battery read over 12v off load and 13. something on 2000 rpm.
