Author Topic: wiring diagram  (Read 4336 times)
Offline bobthebuilder
wiring diagram
« on: May 04, 2011, 09:12:43 PM »
Help Guys, Going nuts trying to rewire KO 750 seam to end up with more wires than connections, suspect previous owner may have tired his own version, diagrams I have seen so far are very static and don't really let you see how it come from the harness to all the relevant connections, any help would be appreciated,
Cheers Jock. ???
Offline Seamus
Re: wiring diagram
« Reply #1 on: May 04, 2011, 10:07:47 PM »
Which manuals do you have? I have the Haynes, a Clymer (with a colour diagram that I can scan) tend to be US but good enough.
I also have a download of a Honda manual. I will see if I can find the source if it is any use. I also have the Mark Paris book, which has a good section on wiring
Let me know
Seamus
Offline Seamus
Re: wiring diagram
« Reply #2 on: May 04, 2011, 10:11:37 PM »
« Last Edit: May 04, 2011, 10:13:19 PM by Seamus »
Re: wiring diagram
« Reply #3 on: May 05, 2011, 09:09:03 AM »
I scanned the wiring diagram from the handbook of my CB750F1 to my PC, then I could blow up sections, print them off and colour them in to help me understand waht I was seeing on the bike.
Den
Re: wiring diagram
« Reply #4 on: May 06, 2011, 02:06:26 PM »
Hi All,
Thanks for all replies on ko wiring think I have solved the problem of extra wires, Bike came to me partially stripped with Lucas sealed - beam unit, with no pilot bulb previous owner had cut pilot bulb wires and tucked them inside headlamp unit. Luckily original Stanley Unit was at bottom of box , problem solved hopefully.
Thanks again for help.
Offline the-chauffeur
Re: wiring diagram
« Reply #5 on: May 11, 2011, 12:32:08 AM »
Bit late, I know, but this interactive guide might help . . .
Offline Seamus
Re: wiring diagram
« Reply #6 on: May 12, 2011, 07:56:52 AM »
That was a good find. Nicely presented bit of info.
Seamus
