Author Topic: Bleed nipple stuck  (Read 5103 times)
Offline florence
Bleed nipple stuck
« on: May 19, 2011, 08:32:54 AM »
Has anyone successfully removed a fused bleed nipple from a brake caliper and, if so, how is it done?
Offline z1100r
    • Home Pages
Re: Bleed nipple stuck
« Reply #1 on: May 19, 2011, 08:44:01 AM »
 I did recently and it took me ages...that was with the caliper off the bike and alot of heat using my plastic welder electric heat gun - paint stripper heat gun. Alot of back and forth - more heat - more Wd40..blah blah. If its on the bike and full of fluid I dont hold out much hope.
Offline florence
« Reply #2 on: May 19, 2011, 09:15:54 AM »
No, this one is off the bike and spare.  The one on my bike has a special adapter on top of the feed, a much better design.
Thanks, I will try heat.
Offline z1100r
    • Home Pages
« Reply #3 on: May 19, 2011, 09:21:22 AM »
 Well seriously hot then...not just a woft...you mustn't be able to touch it, spit will sizzle like mad. Be very careful keeping the spanner/socket square as you 'crack' it. if it does 'crack' - move a bit - then with a bit of patience you'll do it.
« Reply #4 on: May 19, 2011, 01:40:11 PM »
No spanner, long socket with a "T" handle to even the pressure , or clamp the nipple in the vice and turn the cylider away from it.
I seem to be doing a caliper reconditioning service at present (2 in a month) if you want to post it to me, if it breaks I have the repair kits
