Author Topic: Removing/changing main jets on 78 CB550K3  (Read 7436 times)
Offline stidds
« on: May 27, 2011, 10:04:04 PM »
I have a 1978 CB550K3 with Kehin PD46C carburettors, I need to change the main jets, but I cannot see how to change them.
When I remove the main jets they are attached (very well indeed) to the emulsion tubes, my Haynes manual carb diagram show that they are pressed together with an O ring, now this must be a bloody good fit as I cannot see a join.
Am I (well my manual) correct and that they need separating or am I missing something simple?
Sean
Offline z1100r
    • Home Pages
Re: Removing/changing main jets on 78 CB550K3
« Reply #1 on: May 28, 2011, 12:54:16 PM »
 Same to you as Mickwinf  see :- http://data.sohc4.net/SM500/HSM500550_16.pdf
Offline mickwinf
« Reply #2 on: May 28, 2011, 07:12:51 PM »
hi Sean the k3 is diffeent to the pics in the haynes manual the main jet just screws into the emulsion tube part with no seal, i just tried one off a spare carb. Mick
Offline stidds
« Reply #3 on: May 28, 2011, 07:34:23 PM »
Thanks guys, had a look and found it easy to remove.
I just didn't want to go in all guns blazing and screw something up.
Sean
Offline andy_c101
  • Gone but not forgotten.....
« Reply #4 on: May 29, 2011, 10:02:21 PM »
If your carbs are apart, I recommend you also take out the pilot jets as well for cleaning - especially if its been standing for a long time.
Thefine pilot jets ("slow jets") need to be clean to stand any chance of a smooth tick over, (in my experience).
& remember the pilot jets on the K3 are pressed in.
http://www.sohc.co.uk/index.php?topic=3283.msg12138#msg12138
Offline stidds
« Reply #5 on: May 29, 2011, 11:50:36 PM »
Thanks Andy, I took everything apart and cleaned the lot.  They run fine now and ticks over really well.
Sean
