Author Topic: Fuel tap 400/4  (Read 5618 times)
Offline randka
Fuel tap 400/4
« on: May 30, 2011, 02:05:57 PM »
Has anybody got any tips for stopping a weeping fuel tap, I recently replaced the strainer and rubber washer with a kit supplied by Silvers but they dont stock a rebuid kit for the tap body, it seems to be weeping were the turn key is , I have tried everything so any ideas would be appreciated
Re: Fuel tap 400/4
« Reply #1 on: May 31, 2011, 01:25:34 PM »
Is there a gasket in there?
If so, use it as a pattern and cut a new one from brown paper.
Offline randka
Re: Fuel tap 400/4
« Reply #2 on: May 31, 2011, 05:29:33 PM »
Hi Steve, I have had the tap apart a couple of times to clean etc because of the leak, there is an O ring type gasket in there so I assume its not doing its job because of age, I thought I could just get one easily but it hasn't been the case.
Re: Fuel tap 400/4
« Reply #3 on: May 31, 2011, 05:55:08 PM »
O-rings are tricky.
If you can measure it accurately, BryanJ has been known to be able to find an 0-ring or two in his Alladin's Cave (garage)
