Author Topic: Rewiring K2 with later high beam switch  (Read 16344 times)
Offline the-chauffeur
Re: Rewiring K2 with later high beam switch
« Reply #15 on: June 18, 2011, 08:40:46 PM »
Pete - thanks so much for the kind words.  I thought about using copper grease on the base gasket but decided against it for no very good reason.  Should've gone with my first instincts, but again, I've got another spare if the one that's on there turns out to be dead.
Your post couldn't've come at a better time, because guess what?  Bikewise, today got a lot worse.
After putting the 750 to one side, I decided to go get some food and thought I'd take the SL350.  What could go wrong?  Well, the top of the left shock absorber separating itself from the bottom four miles out wasn't something that would've immediately sprung to mind.  But that's exactly what it did.  Oddly, I didn't notice anything wrong until I got off the bike (although the spring had wedged itself against the frame, so I didn't lose much in the way of rebound) but I needed recovering 'cos there was no way I was riding it like that once I'd noticed it.  So I don't think I was ever in any real danger.
However, what the separation did do was take a chunk out of the rare-as-hell-and-virtually-irreplaceable sidepanel which I spent a bundle on getting painted.  Fortunately, it's not holed or cracked - I think it's just taken a layer out about the size of a 10p coin - but colour matching is going to be a pig of a job.  On the upside, Silvers have got the collars that disappeared themselves when the shock disassembled itself are still, so at least that's not lost.  Guess that's one of the benefits of such a rare bike - no-one else needs the parts.
It's not good, but I can only look at the whole sorry mess and say hey, it could've been so much worse.  I'm still in one piece, and the remedial work on both bikes is more time than money (well, maybe not the sidepanel . . . ).
Right, let's tear down that 750.
« Last Edit: June 18, 2011, 11:23:22 PM by the-chauffeur »
« Reply #16 on: June 18, 2011, 11:21:50 PM »
2 hours - that's how long it's taken me to get the engine down to the crankcases and tidy the garage.  Not bad, huh?
Looking at the areas where the leak was emanating from, it seems to be attributable to one of a couple of things - the favourites are a poor seal around the thin strip of gasket covering the case near the front of the cam chain guide, or something due south of the up oilways (round the rear cylinder studs) from the crankcase.  The surfaces are completely flat, so it's not warp or scarring, but I can't remember if I used new o-rings around the oilway studs.  Having said that, if they weren't sealing, I would have thought any leakage would have taken the much shorter route to air - i.e. go out from the cylinders backwards and onto the top of the crankcases.  There was also nothing particularly unusual about the o-rings around the cylinder bases.  Whatever, it shouldn't be a particularly tricky fix.
I'll let the faces a while to dry out, and run them over with thinners before putting everything back.  I'll also pull the valves, check the guides, clean up the seats, gently re-lap the faces and put on new seals.  I already kinda live by Brian's earlier maxim of never throwing anything away, and numerous engine gasket kits have provided me with more than enough spares.  'll also clean the cylinder bases and reseat the larger o-rings before reassembly.
Suffice it to say I've got the bit between my teeth.  The problems I've got are ones that I understand and can fix, so it's just a matter of getting on and doing it.  I find it's easier to be motivated by this kind of situation than be down about it, 'cos I'm pretty sure it just needs a bit more twiddling to get it perfect.  And by perfect I mean oil tight and running without smoke.  Talking of which, pistons 1 and 2 had some carbon deposits on the tops, but 3 and 4 (remember 4 was smoking a bit) were pretty much clean as a whistle.  Dunno what - if anything - that means.
Tired now.  Busy day.
« Last Edit: June 18, 2011, 11:27:32 PM by the-chauffeur »
Offline UK Pete
« Reply #17 on: June 19, 2011, 08:59:18 AM »
Well done Neil, positive attitude gets you everywhere, these old bike can be a test of anyones patience, i have lots of oldish jap bikes each one has presented me with some sort of problem , but evrything comes good eventually,
I am now off to ride some of mine today i think first of all i will take the 750F2 up the oakdene cafe, then come back and take the K1 out for a 30 mile or so ride just to keep it healthy, then when back from that ride i will go ballistic on my FZ1, for an hour to pump up the adrenaline, it keeps you feeling young you know
pete
« Reply #18 on: June 20, 2011, 12:30:59 AM »
Looks like the weather held for you today . . .
On further inspection, it looks to me like the leak around the cylinder base was caused by a casting flaw in the underside of the cylinder block.  There's a small patch around one of the oil returns that isn't completely flat - it's very slightly rough.  It doesn't run the width of the band from the return through to the engine exterior, but the pressure inside the crankcases now that the oil pump has been overhauled and works at pretty much maximum potential is enough to force tiny amounts of oil/air out.
So I've refitted the base gasket after coating most of it in copper grease and the bit that sits over the rough patch (and areas in front of the oil returns) with thin coats of sealant on both faces.  Top went back on with pretty much the same ease as the last time I put it together, and there's just a few jobs left for the re-rebuild to be completed.  One benefit of picking up he new head I hadn't foreseen is that it came with better fitting exhaust flanges - the bits that join the exhausts to the head - than I've got on mine.  I never really thought about it until now, but mine were really sloppy, which could explain the with smoke from #4 (I always thought it was an air leak).
So that's cool.
« Reply #19 on: August 03, 2011, 10:40:24 PM »
Well, I thought it was cool.  I was wrong.
After stripping and rebuilding the top end, I got to run the bike last week.  Top end was pretty much fine, and the smoke from #4 was residual oil (WD40 or similar) in the exhaust pipe.  However, I couldn't help notice what seemed to be oil dripping from the front filter housing.  Closer inspection revealed the housing was fine, so the next logical conclusion was that it was old oil that had leaked from the cylinder base, dried on and then liquefied when everything heated up. Sadly, that would just be too easy.
Seems the base gasket leak masked a smaller, but equally significant leak - from the joint between the crankcase halves.  Never seen that before, but it's there. Like the other leak, I'm putting it down to a properly functioning oil pump increasing the internal pressure, but that's little consolation.
Looks like the only remedy is to pull the engine, flip it, unseal and reseal and put it back in again.  At least that way I can be sure it's done right.
I'm sure every step I go forward is getting me closer to having a properly sorted bike, but it sure as hell is putting me through the ringer to get there.
« Reply #20 on: August 03, 2011, 10:47:22 PM »
Do I remember there being an "O" ring in that area?
« Reply #21 on: August 03, 2011, 11:15:25 PM »
Oh yeah - the big one that goes round the oil path dowel.  Both are there - and were new when I put the two halves together last time.
I'm struggling to remember now, but I have a feeling that when I put the bottom half on, I had some trouble with one of the bearing retainers not fitting quite right.  I replaced all of the bearings with SKF's and had to have retaining grooves cut into the sides of a couple of them - and one in particular was a very tight fit.  Anyways, I thought I'd got the cases squared away but hadn't, and had to reopen them - and I guess I disturbed the liquid gasket stuff.
Whatever - it's going to be hard work.  Again.
>-sigh-<
« Last Edit: August 07, 2011, 04:05:46 PM by the-chauffeur »
Offline mick
« Reply #22 on: August 04, 2011, 08:54:23 AM »
Keep plugging away Neil it will be worth it in the end  ;), cheers Mick.
Offline UK Pete
« Reply #23 on: August 04, 2011, 01:11:16 PM »
That engine is giving you so much hassle, i hope you get it oil tight and running fine, maybee if its up and running you can join us at box hill on August 28th, where hopefully a few sohc members will meet up
Pete
« Reply #24 on: August 06, 2011, 11:28:25 PM »
Well, it's been a day of ups and downs.
We pulled the engine earlier today, flipped it and opened it up.  It was fairly obvious where the sealant was missing - there was a space about an inch wide, which is very weird, but hey.  We cleaned the mating faces before applying new sealant and with all that done and the halves bolted back together, we flipped the engine right way up.  Everything checked out (gears and crank-wise) and we're just moving it back to the bike when . . .
 . . . we noticed what looked like a small silver plug that had fallen out of the cases.  On closer inspection (and some hunting with a torch) it appears to be the internal end covering of one of the cylinder studs - I can see the top of one if I look very carefully. The piece of casting is only about the size of a 20p piece and it's a couple of mm thick; there's no thread on it, but it's got a domed indent in the centre. We didn't touch the studs this time - no need.  All we were doing was taking the bottom case off and putting it back on - so I can only assume the end cap had fractured when I replaced the standard studs with heavy duty ones and it been waiting for the right time to fall off . . . and that time happened to be now.
I can't see any other case damage anywhere, and it's certainly not spread or cracked anything else, but what I'm hoping someone can tell me is whether it's safe to run as it is - insofar as will the rough casting hold up to being continually splashed with engine oil?  I know the cases are strong enough as they are, but I'm just a little concerned that the unfinished surface left by the missing cap might be too porous and/or should be resealed to stop it crumbling.
I'm praying that it'll be fine as it is, and that I'm just me being over cautious - I really don't want to go through an entire stripdown again.
>sigh<->again>
« Reply #25 on: August 07, 2011, 10:50:16 AM »
I'll answer my own question for those who're interested with the wisdom of Hondaman:
"Boy, I know all about the hectic part!
The casting: the main reason these were closed on the bottom was to keep oil seepage up those threads to a minimum. Honda has always been concerned that their engines should be dry on the outside. If the engine is still open, you might try using a bit of JB Weld epoxy, fresh and well-mixed, after cleaning the site with acetone or lacquer thinner. This epoxy work well by gripping those pores and sealing into them, and it withstands engine heat easily. It is impervious to hot oil, once cured. It is a mainstay of the repairs I have done to both these aluminum engines and cast-iron ones, for years. But, it must be FRESH, not old, and well-mixed, and applied no more than 3mm (1.8") thick.
It's actually good that the little piece fell out now: it could have popped up into the tranny gears and locked them tight while snapping into a hard shift into 2nd gear near redline. Makes a real mess (and we won't discuss how I know about this little event...). :-D"
Bearing in mind my 350 and 450 both have open ended cylinder stud holes, I reckon it'll be fine as is.  Which is something of a relief - as is the fact that it went when it did and didn't wait to spring a really nasty surprise on me . . .
Offline UK Pete
« Reply #26 on: August 18, 2011, 08:29:43 AM »
Lets hope thats the last of it neil, you deserve a bit of good luck with this engine,
Pete
« Reply #27 on: August 21, 2011, 05:24:13 PM »
Yeah - that's what I thought.  Sadly, the engine has other ideas.
There's a leak between the crankcases in the sprocket area - the part of the cases that sit between the sprocket and gearbox.  Yes, it's definitely there and not the seal behind the sprocket; I cleaned everything with thinners and then put talc on it to see if I could trace the problem (which was oil doing more than just dripping off the bottom of the engine).
Christ.  Either I'm cursed or this f*cking engine is.  Still, it's not a mechanical problem, so it's not an expensive fix;  just time consuming.  Again.
<sigh - again - sigh>
« Reply #28 on: August 22, 2011, 07:20:50 AM »
That might be the locating ring holding the cases slightly apart mate, something physical has to be stopping them going together with all them bolts on it
« Reply #29 on: August 23, 2011, 09:16:43 PM »
Guess that's possible - I know one of them was a pain in the arse to fit.
Having said that, the leak isn't near to or parallel with one of those locators (as far as I can recall).  Also, the hole is sooooo small - and it's only leaking from that point - that I reckon it's the sealant that's the problem.  Added to which, I'd've thought I'd have bigger problems than a pinhole oil leak to worry about if one of the locators was out of whack.   ;)
I'll let you know . . .
