Author Topic: rear hub  (Read 3161 times)
Offline cobra
rear hub
« on: October 10, 2011, 03:57:28 PM »
will the sprocket carrier on a cb750 sohc disc rear brake fit a drum rear brake? the reason i ask is i am trying to locate a drum rear wheel hub or complete rear wheel, without any success, so it looks like ebay, problem is nobody wants to sell a complete wheel, its a wheel, a brake plate, and a sprocket carrier, i have a carrier off my disc brake, so do i need to buy all three parts or will i get away with two.
Offline Seamus
Re: rear hub
« Reply #1 on: October 11, 2011, 07:28:22 PM »
I think so, the part number for a carrier on a K2 seems to be 42601-341-000 and that also works for an F series bike.
May be worth you cross checking on Motogrid.com to be certain.
Best of luck
Seamus
Offline cobra
Re: rear hub
« Reply #2 on: October 12, 2011, 10:22:24 AM »
thanks Seamus, i thought they looked the same. i have checked both, but not had the two side by side, but i couldnt see any difference between them.
Re: rear hub
« Reply #3 on: October 12, 2011, 04:10:50 PM »
42601 don't come up on the part search any more but 42609 does and it fits K0 to 76F
Offline Seamus
Re: rear hub
« Reply #4 on: October 13, 2011, 05:27:17 PM »
You are right there Bryan. A slight typing error (and the memory of a goldfish).
