Author Topic: 500 K cafe racer conversion - build thread  (Read 149591 times)
Offline Ewan 500 K1
  • jings crivens help ma boab
    • Adams Bros Probe 2001
Getting Silly
« Reply #150 on: September 14, 2013, 12:59:02 PM »
« Last Edit: September 14, 2013, 01:02:57 PM by Ewan 500 K1 »
500K1 basket case for later
Offline Ewan 500 K1
Re: 500 K cafe racer conversion - build thread
« Reply #151 on: September 15, 2013, 04:19:48 PM »
Sooner walk to London with a nail in my shoe that use those. URGH!!!!!!
;D ;D ;D .. think I was havin a momentary bout of madness
« Last Edit: September 15, 2013, 04:48:54 PM by Ewan 500 K1 »
Offline Ewan 500 K1
« Reply #152 on: September 17, 2013, 10:28:04 PM »
Quite a bit of choice for proper whitewall tyres for 19" front ... but only thing I can find for 18" back are Cockers at (wait for it ) .... £250 to £300. No way ! I might be a poser , but thats a few ££ too far . List of all front and rear whitewalls I can find in the UK attached as a word doc.
« Last Edit: September 17, 2013, 10:35:14 PM by Ewan 500 K1 »
Offline Ewan 500 K1
« Reply #153 on: September 22, 2013, 03:57:29 PM »
NHK ODM500 steering damper (as originally fitted to the Kawa Z1) in place. Much more pleased with this one, it sits much better than the GSXR one. At full right hand lock it just misses hitting the engine. Next up, a wee bit of welding on the frame and then off to the powder coater.
Offline Ewan 500 K1
« Reply #154 on: December 21, 2013, 11:11:17 AM »
Had to extend the steering stop by 10mm either side to stop the clubman bars banging off the tank.
Also, one of the rear peg mounts was corroded through and needed welding .
Finally .... tarozzi rear sets have arrived :) These will be mounted on the rear passenger footpegs instead of using the tarozzi mounting bracket
...... so nearly there as ever. Just need to get powder coated and the front muguard rechromed. Bring it on Santa.
These new phot options are great Steve  ;D ;D
« Last Edit: December 21, 2013, 12:00:33 PM by Ewan 500 K1 »
Offline Green1
« Reply #155 on: December 21, 2013, 08:23:47 PM »
Ewan did you disside on a frame finish yet
Mick
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Triumph tiger 800
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
Offline Ewan 500 K1
« Reply #156 on: December 22, 2013, 06:36:52 PM »
dissided to go borin black Mick  ???
Offline Ewan 500 K1
« Reply #157 on: December 30, 2013, 05:45:01 PM »
Drilled and tapped both caliper arms today to add grease nipples. The nipples extend through the caliper arm body by about a millimetre so will need a wee washer added so that they dont rub on the pivot pin.
[ Guests cannot view attachments ] [ Guests cannot view attachments ] [ Guests cannot view attachments ]
Also helicoiled the caliper arm mounting bolt holes on one of the forktubes ... near disaster with one hole. The helicoil didnt see to go in right and the bolt was stiff to turn .... = sheared bolt. Managed to drill it and the helicoil out cleanly , retapped and rehelicoiled (phew)
Santa bought me an hour in a gyrocopter from http://www.chrisjonesgyroplanes.com/ instead of gettin me a powdercoating or chroming voucher. I cant complain tooooooooooooo much but if he thinks I'm giving him a hand in a reindeer free present run round the chimneys next year he's got another thing comin. Powdercoatin on hold till a few bills are paid
« Last Edit: December 31, 2013, 12:07:58 AM by Ewan 500 K1 »
Offline Ewan 500 K1
« Reply #158 on: December 31, 2013, 01:55:25 PM »
Yeah I have to add a washer my my grease nipples as well Ewan, it would help to flatten down the area where the nipple goes as it helps seal it a little.
     yeah , forgot about that bit oddjob. I'll get onto it
Offline Ewan 500 K1
« Reply #159 on: January 04, 2014, 05:30:08 PM »
Rear of both caliper arms flattened off where grease nipples added (thanks for reminder oddjob). Modified washers also added under the grease nipples to prevent then from extending through the caliper arm body and and rubbing off the caliper arm pins
« Last Edit: January 04, 2014, 05:35:37 PM by Ewan 500 K1 »
Offline Ewan 500 K1
« Reply #160 on: January 05, 2014, 12:34:43 AM »
no, not yet applied the grease gun yet OJ, as ever with this reconstruction its all theory till I sort out the powdercoatin an reassemble  the meccano. Got some 90 degree nipples , but they were too big an ugly to the eye  ???
« Last Edit: January 05, 2014, 12:36:36 AM by Ewan 500 K1 »
Offline Ewan 500 K1
Re: 500 K cafe racer conversion - powdercoating at last
« Reply #161 on: January 06, 2014, 07:48:43 PM »
Dropped the frame, swingarm, botton yoke, rear brake stay, rear brake rod and engine mounts off at WTA Coatings, just outside annan, today   ;D ;D ;D ;D
http://www.wtacoatings.co.uk/
« Last Edit: January 11, 2014, 11:25:53 AM by Ewan 500 K1 »
Offline Ewan 500 K1
Re: 500 K cafe racer conversion - tacho plugs
« Reply #162 on: January 11, 2014, 11:19:46 AM »
Having failed to find any UK / european suppliers of plugs to blank off the tacho drive hole in the rocker cover, I ordered a couple from america, both meant to be for 750's.
First one, $16 inc P&P from http://www.workingclasschoppers.com . This one is a bit on the loose side and doesnt have a groove for an o-ring. I've stuck on ebay at http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=181299549879
Next one from member 754 on the US site , this is a much snugger fit and has an o-ring groove. $20 delivered. I think he still has more available.
« Last Edit: January 11, 2014, 12:02:05 PM by Ewan 500 K1 »
Offline kendo57
« Reply #163 on: January 11, 2014, 10:03:46 PM »
You could just remove the drive and fit a small flat plate over the hole  using the single
 bolt to hold it in place. Mine was like that when I bought it and works fine.
Offline Ewan 500 K1
« Reply #164 on: January 11, 2014, 10:07:11 PM »
Never thought of that Kendo... probs looks tidier too
