Author Topic: 500 K cafe racer conversion - build thread  (Read 147830 times)
Offline Ewan 500 K1
  • jings crivens help ma boab
    • Adams Bros Probe 2001
Re: 500 K cafe racer conversion - build thread
« Reply #180 on: May 19, 2014, 08:58:44 PM »
great work Ewan,
 I shall be very interested when its finished and running,
 good luck,and keep us informed !!!
Thanks John, I'm sure there will be a few niggles along the way that I might need to ask the oracle about ;)   Today I realised that I'd left out one of oil o-rings that sits between the cyinder head and the barrels when I rebuilt the top end after I'd been in renewing the piston rings and fixing the cam chain adjuster... so had to strip the top end down again.... bugger
« Last Edit: May 19, 2014, 11:39:44 PM by Ewan 500 K1 »
500K1 basket case for later
Offline Ewan 500 K1
Re: 500 K cafe racer conversion - bloody carbs
« Reply #181 on: May 20, 2014, 10:22:59 PM »
Tonight I thought I'd check the carbs over before bench syncing them. Main jets are 110, pilots are 40 and needles are in the middle groove  and joy of joys ............the wee bolt that joins the carb slide to the lifting mechanism on one of the carbs sheared  >:(   ..... more time needed that wisnae planned for  ::)
... luckily I have a  spare carb body I can canabalise if the worst comes to the worst :o
« Last Edit: May 20, 2014, 10:26:00 PM by Ewan 500 K1 »
Offline simonster
« Reply #182 on: May 23, 2014, 01:32:35 PM »
Hi Ewan,
Your Cafe conversion is looking really good and a great thread too. I like the clubman bars you are using and i'm trying to source something similar. I have researched these to death and all the stock bars don't drop enough and the pull is too wide for the look i want!... Are these a special or off the shelf? cheers.
Offline Ewan 500 K1
« Reply #183 on: May 23, 2014, 01:58:30 PM »
Hi Ewan,
Hi Si, got them 2nd hand off ebay.  They do clatter off the tank in the position I like, so had to extend the steering stop on the bottom yolk 10cm either way
Offline simonster
« Reply #184 on: May 25, 2014, 03:38:09 PM »
Hi Ewan,
You must have dropped lucky there. I have now bought two styles of clubman/cafe bars and I'm still not happy how they look. It would help greatly if you are able to measure yours for the width, rise, centre width and pullback of the bars, it may narrow my search for the perfect bars. Thanks in advance! Simon
Offline cb750stu
« Reply #185 on: May 26, 2014, 11:29:29 AM »
Hi Ewan the bikes looking good so far well done !!
Have you tried the kickstart to make sure it clears everything ?? I fitted the tarozzi rearsets to my 750 and it hits the brake pedal I think I might have to heat it and bend it so it clears, yours may be different though !!
1976 CB750 F1 SS in bits !!! but getting there
Offline Ewan 500 K1
« Reply #186 on: June 01, 2014, 08:47:59 PM »
Hi Stu, I think if I'd used the standard tarozzi mounts there might have been an issue... but I've mounted the sets further back .. on the passenger peg mounts , which is better suited to the guiallari seat riding position. Kikstart JUST clears the brake pedal in this position
Offline Ewan 500 K1
« Reply #187 on: June 01, 2014, 08:49:02 PM »
Hi Ewan,
Hi Si, been away for a week, will measure up tomorrow and let u know
Offline simonster
« Reply #188 on: June 02, 2014, 11:57:47 AM »
cheers ewan, no major rush pal.
Offline Ewan 500 K1
« Reply #189 on: June 02, 2014, 08:16:57 PM »
here ya go .... rough(ish) dimensions.  You seen tarozzi's  adjustable bars  & clip ons ?
http://www.discovolantemoto.co.uk/clipons-65-c.asp
« Last Edit: June 02, 2014, 08:21:21 PM by Ewan 500 K1 »
Offline Ewan 500 K1
« Reply #190 on: June 02, 2014, 09:50:30 PM »
Time to get the 500 four back on the road after a break of three years, this time this time to finish the cafe racer job that was started about 17 years ago
Done : Full Engine rebuild about 3000 miles ago.
To do:
K&N Air Filters (done)
Straight through pipes (done)
Rejet with 110 mains/ clean / syncronise carbs (done)
Rebuild both wheels with new rims & spokes(done)
Dual Disc front brake conversion (done)
Drill front sprocket cover
Remodel Front Mudguard (done)
Drill brake discs (done)
Detag & shorten Frame (done)
Replace stock speedo/ rev counter (done)
Ace Bars (done)
Custom Tarozzi Rear Sets on rear foot peg hangers (done)
Relocate Battery  (done)
Rewire from front to back and everywhere in between (done)
New Headlight (done)
New idicators (done)
New speedo (done)
New rear lights set up
New longer rear shocks (done)
New front mudguard (done)
Polish alloy (done)
Braided Stainless Fuel & Brake Hoses (done)
Stainless Bolts througout (done)
Refurbish Front Forks (done)
New Rear Shock Swing Arm Bushes (done)
New Plugs
Powder Coat the frame
Investigate effect of longer rear shocks on bike geometry and make front end adjustments if necessary (nearly done)
Fit Steering Damper (done)
Fit grease nipples to front break caliper arm pivot points (done)
Tune up carbs
Get MOT, tax and insurance
« Reply #191 on: June 02, 2014, 10:03:01 PM »
wow !!
  thats a whole heap of work,
   lets us know how it handles?
  and how the motor runs
Offline Ewan 500 K1
« Reply #192 on: June 02, 2014, 10:23:04 PM »
wow !!
surely cannae be long now ;)   Engine was fully rebuilt about 3000 miles ago, including new primary chain, new crankshaft shells, camchain & tensioner. Ran sweet before the rebuild, though needs a bit of carb fiddling.
« Last Edit: June 02, 2014, 10:25:13 PM by Ewan 500 K1 »
Offline simonster
« Reply #193 on: June 03, 2014, 10:27:13 AM »
Thanks for the bar geometrics... very comprehensive and much appreciated. Keep up the good work with the cafe mogrel.
Offline Ewan 500 K1
« Reply #194 on: June 04, 2014, 08:27:34 PM »
Carb sorted, though I had to wreck the lift mechaism roller drilling the remains of the bolt out of it so that the roller could slide out. Replaced that roller with my spare one..... Electrics this weekend. Lost the bloody carmera up a hill on islo skye so nae photies for a bit.
« Last Edit: June 04, 2014, 08:29:07 PM by Ewan 500 K1 »
