500 K cafe racer conversion - build thread
5
6
7
8
15
Topic: 500 K cafe racer conversion - build thread (Read 147758 times)
Ewan 500 K1
jings crivens help ma boab
New Avon Roadriders
Reply #75 on:
July 31, 2013, 09:38:55 PM »
new rubber, shame the boys in the shop put the front one on the wrong way round
next .. back to the tyre shop then ... the scary wiring loom renewal
Last Edit: August 22, 2013, 02:59:44 PM by Ewan 500 K
500K1/550K3 mongrel cafe racer project for now at
http://www.sohc.co.uk/index.php/topic,4120.0.html
500K1 basket case for later
Ewan 500 K1
rewiring
Reply #76 on:
July 31, 2013, 11:02:24 PM »
Wiring Loom Renewal Resources:
Wire, Bullet Connectors etc Suppiers:
http://kojaycat.co.uk/
http://www.autoelectricsupplies.co.uk/
http://www.vehicle-wiring-products.eu/VWP-onlinestore/home/homepage.php
http://www.sgmotorsport.co.uk/
http://stores.ebay.com/Atop-Authentic-Auction/PET-Expandable-Sleeving-/_i.html?_fsub=2578659015&_sid=879188535&_trksid=p4634.c0.m322
500 four Wiring Diagrams;
http://oldmanhonda.com/MC/wiring500.html
http://kojaycat.co.uk/epages/950000457.sf/en_GB/?ObjectPath=/Shops/950000457/Categories/Motorcycle_Wiring_Diagrams
(this ones well worth the £15 it costs)
Clymer one, see picture below
Generic Wiring Diagrams
http://www.hondachopper.com/garage/simple_wiring_diagram/simple_wiring_diagram.html
http://www.ripper1.com/tech/wiring/wiring2.jpg
http://www.ripper1.com/tech/wiring/wiring1.jpg
How To Guides and Technical Stuff etc
http://www.sohc.co.uk/index.php?action=dlattach;topic=5432.0;attach=4217;image
Nice simple one on how to use tools and fix connectors etc
http://www.colorado.edu/physics/EducationIssues/podolefsky/electric_motorcycle_howto_wiring.html
The John Partridge one at:
http://www.triumphrat.net/twins-technical-talk/229345-idiots-guide-to-making-your-own-motorcycle-wiring-harness.html
Honda Motorcycle Electrics Manual:
http://minus.com/lbtlR5awJwSHPy
In General ~ but not always !
A RED wire is permanently live (+ve), ie 'hot wired' to the battery.
A BLACK wire is switched live, ie only +ve when you turn the ignition on.
A GREEN wire is permanently grounded (-ve). Ie at all times connected to the -ve terminal of the battery, via the frame.
A LIGHT GREEN wire is switched earth, ie only connected to the frame when you press the horn button.
Last Edit: August 22, 2013, 02:59:01 PM by Ewan 500 K
Ewan 500 K1
rewiring
Reply #77 on:
August 05, 2013, 08:24:28 PM »
old loom a bit knackered and burnt at the edges;
Last Edit: August 22, 2013, 02:58:30 PM by Ewan 500 K
Ewan 500 K1
rewiring
Reply #78 on:
August 05, 2013, 08:30:25 PM »
tools:
crimper £9 from VWP
Wire stripper / crimper £8 from Aldi
Last Edit: August 22, 2013, 02:58:09 PM by Ewan 500 K
Ewan 500 K1
rewiring
Reply #79 on:
August 05, 2013, 08:35:14 PM »
stripping wire
Last Edit: August 22, 2013, 02:57:45 PM by Ewan 500 K
Ewan 500 K1
rewiring
Reply #80 on:
August 05, 2013, 08:37:01 PM »
crimping
Last Edit: August 22, 2013, 02:57:31 PM by Ewan 500 K
Ewan 500 K1
rewiring
Reply #81 on:
August 05, 2013, 08:40:31 PM »
crimped
Last Edit: August 22, 2013, 02:56:58 PM by Ewan 500 K
Ewan 500 K1
rewiring
Reply #82 on:
August 05, 2013, 08:43:14 PM »
+ heat shrink sleeve
Last Edit: August 22, 2013, 02:56:38 PM by Ewan 500 K
Ewan 500 K1
rewiring
Reply #83 on:
August 05, 2013, 08:44:58 PM »
+ plastic cover ... should be pretty secure now
Last Edit: August 22, 2013, 02:56:18 PM by Ewan 500 K
Ewan 500 K1
rewiring
Reply #84 on:
August 05, 2013, 08:48:01 PM »
bodged battery holder for under the seat hump (cheers Mick
Last Edit: August 22, 2013, 02:55:43 PM by Ewan 500 K
Ewan 500 K1
rewiring
Reply #85 on:
August 05, 2013, 08:51:20 PM »
new headlamp spaghetti and idiot lights
Last Edit: August 22, 2013, 02:55:20 PM by Ewan 500 K
Ewan 500 K1
tank trim
Reply #86 on:
August 05, 2013, 08:53:24 PM »
Halfords Screen Trim used for tank trim
(later .. Halfords are a rip off, you can get the same stuff for half the price off ebay)
Last Edit: August 31, 2013, 01:25:01 AM by Ewan 500 K
Ewan 500 K1
Dual Discs
Reply #87 on:
August 05, 2013, 09:01:22 PM »
bit of a funny one when refining the dual discs set up today. The caliper arm for the additional disc on the right hand (speedo drive Side) was perfectly aligned with the disc without any need to mess around contrary to al expectation (photo one)
(laterz... no thats wrong,
See my seperate post at
http://www.sohc.co.uk/index.php?topic=5571.msg27566#msg27566
for the pain and agony of setting up my dual discs
but the original set up on the left hand side was misaligned (second photo) and had to be brought into line by putting some washers in between the caliper arm an the fork.... although thinking about it now maybe the mudgaurd mounting bracket is supposed to go between the caliper arm and the fork leg. Just now I've got the caliper arm directy onto the foork with the mudguard bracket on top of the caliper arm.
Last Edit: August 25, 2013, 06:54:59 PM by Ewan 500 K
Ewan 500 K1
Re: 500 K cafe racer conversion - build thread
Reply #88 on:
August 05, 2013, 09:04:21 PM »
so , thats it for now. Stuck the tank and seat back on and sat with a bottle of beer and a fag an just looked at it for a while....
Still to do ... finish the electrics, get a hold of longer rear shocks, buy some rearests, powder coat the frame and sort out the rear light / number plate set up
Last Edit: August 05, 2013, 09:22:27 PM by Ewan 500 K
Ewan 500 K1
Re: 500 K cafe racer - new loom finished
Reply #89 on:
August 20, 2013, 09:51:46 PM »
New custom wiring loom all finished. Amazingly everything worked first time except the starter button which needed grounding to the frame. .. and the crappy mini indicators that I got from HALFORDS, which blew the fuse and screwed the relay. Old indicators still working fine , so there must be a fault in the halfords ones, they have some bad reviews. Frame all stripped again ready to go and get powder coated. New fork seals arrived. Cant get new rear shocks from Hagon till end of September and Tarozzi are on holiday till Sept , so rearsets are on hold too. So near to finishing now
Last Edit: August 20, 2013, 10:06:04 PM by Ewan 500 K
5
6
7
8
15
