Author Topic: 750f1 carbs 1978  (Read 4090 times)
Offline kifer
750f1 carbs 1978
« on: January 14, 2012, 05:26:31 PM »
Hi out there would any body know where to buy o-rings,  I need the ones that go on the fuel tee's between the carbs 8 in total,
Rest of seals / gaskets good so did not want to go down carb kit route @
Re: 750f1 carbs 1978
« Reply #1 on: January 14, 2012, 06:39:17 PM »
I seem to remember getting some from a local motor factors last time I needed some, just took one of the tee pieces in and tried various ones from their "selection box", under
Offline UK Pete
« Reply #2 on: January 14, 2012, 07:27:18 PM »
Offline kifer
« Reply #3 on: January 15, 2012, 04:07:04 PM »
Thanks to both you guys much appreciated will go with one of them.
« Reply #4 on: January 16, 2012, 06:58:12 AM »
IF they are the same size as the K2-K4 they are 7.8 x 1.9 mm
Offline kifer
« Reply #5 on: January 16, 2012, 09:31:27 PM »
Thanks for that will get the vernier on one and check,
