Author Topic: carb rebuild anything I should look out for ?  (Read 4737 times)
Offline bluemouse1006
« on: January 24, 2012, 04:28:04 PM »
Hi
just got some carb rebuild kits for my K5 CB750 anything I should look out for Ive cleaned all the bodies and will be tackling the rebuild at the weekend .. I see in the kit the needle has slots in it which slot do I set it too with the clip?
any advise much appreciated
Amos  ;D
Amos
Re: carb rebuild anything I should look out for ?
« Reply #1 on: January 24, 2012, 04:55:59 PM »
Hi,
You do not say if the kits are copies or Honda.I have seen lots on other forums that the copies the needle jets are not the same and can have running problems just as I have.I always thought that the clip goes on the middle ring but alot put it back as they found it.I will soon be fitting new Honda needles and will let all know if it fixed my problem and if so what my problem was with these after market kits.
Good Luck
Offline mick
« Reply #2 on: January 24, 2012, 06:47:16 PM »
Middle slot should be fine Amos
« Reply #3 on: January 25, 2012, 04:13:41 PM »
Thanks for the replies  Ill fit them in the middle and see how they go although if I find them all at the top etc ill give that a go,they are copies and not from Honda but hope they will be OK if not ill just refit the old needles etc. back and see how I go
Thanks again
Amos  ;D
Amos
« Reply #4 on: January 25, 2012, 06:41:42 PM »
started stripping the carbs the main jet on the old carb part seems to be stamped with 105 and the new one has 110 on it does this make a big difference the needle was set in the middle so I fitted the new needle in the same place
Any ideas
Thanks Amos  :o
Amos
Offline mick
« Reply #5 on: January 25, 2012, 09:19:59 PM »
Amos you may find this helpful  ;), cheers Mick.
http://www.motorcycleproject.com/motorcycle/text/specs.html
« Reply #6 on: January 26, 2012, 04:12:23 PM »
Great bit of info seems my carbs are from a 1976 f with 105 main jets same carb though as a k 69/76 so will be happy to leave the 110 jets in and try them as they are the ones listed for my bike !
Thanks again great  help will let you know how the start up goes at the weekend
Amos  ???
Amos
« Reply #7 on: January 29, 2012, 10:13:24 AM »
Hi
Finished the carb rebuild yesterday once it warmed up and I balanced the carbs with gauges it seems to run ok But The clutch drags like hell (ill start another topic for that )
Thanks for the additional info
Amos
Amos
