CB750
4th gear failing to engage.
Topic: 4th gear failing to engage. (Read 12825 times)
Warthog1959
Newbie
March 11, 2012, 02:56:33 PM »
My engine has recently been rebuilt and is running well. However it is failing to engage into 4th and has to be put back into 3rd to engage drive. Is this likely to be clutch adjustment?
LesterPiglet
1977 CB550F2
Re: 4th gear failing to engage.
March 11, 2012, 03:04:31 PM »
No. The clutch will affect all gears equally. What was rebuilt and has this problem been there since the rebuild or happened after a while?
hairygit
March 11, 2012, 03:05:02 PM »
No, sadly not, this sounds like a selector fork/drum or thrust washers between gears problem
Warthog1959
Newbie
March 11, 2012, 03:17:33 PM »
The entire engine was rebuilt, This is the 1st ride. This needed doing because there was a crack in the crankcase in front of the front sprocket. 4th gear worked before the build, however was subject to the occasional false neutral. All bearings and seals were replaced. Clutch pressure plate was replaced as this was functional but broken.
hairygit
March 11, 2012, 03:56:35 PM »
Did you inspect the dogs on the gears while it was apart, also the wear on the selector forks (I would hope you paid particular attention to the wear patterns on the forks if it was previously giving trouble!) Were the gear clusters dismantled? was a thrust washer lost/omitted/broken up into tiny bits?
Warthog1959
Newbie
March 11, 2012, 04:36:17 PM »
No broken washers the gear cluster was inspected, but not Dismantled.. Possibly selector forks then? Can't say I would have been able to recognise wear on these.
hairygit
March 11, 2012, 04:48:33 PM »
They tend to wear at the points where they actually contact the gears, also if someone has persistantly tried forcing gears in they can bend to the extent they wont move the gear across enough to engage
Warthog1959
Newbie
March 11, 2012, 04:55:51 PM »
Ok thanks. I'm not sure what to do now, selector forks don't appear to be available. Shame summer has just arrived.
LesterPiglet
1977 CB550F2
March 11, 2012, 05:14:04 PM »
What model is the bike?
Warthog1959
Newbie
March 11, 2012, 06:14:12 PM »
It's an f2 super sport 78
steff750
SOHC Expert
THE POWER OF DREAMS
Reply #10 on:
March 11, 2012, 06:29:12 PM »
are you sure its fourth gear and not fifth gear that's not engaging,the reason i ask is, if you have left out the half noon rings that hold the gearbox bearings in place or you have used new bearings without the slots cut in them the slots are there to hold the bearings in place and stop any side movement of the gear cluster,then the main shaft will move over with bearings and the gear selector drum making the gears fail to engage
bad news is engine out again you might get away with just removing lower crankcase and work on engine upside-down
Warthog1959
Newbie
Reply #11 on:
March 11, 2012, 06:38:53 PM »
We have an engine mount swivel to do that with. i didn't replace the bearings on the gear cluster. I did just get a set of selector forks and a shaft for an F2 for £22. didn't actually dismantle the gear cluster.
Is there any possibility that this is the selector drum. I have a spare used one of those also.
Warthog1959
Newbie
Reply #12 on:
March 11, 2012, 06:40:27 PM »
Sorry yes it is 4th. I've carefully counted 1 down and 2 up, then nothing.
hairygit
Reply #13 on:
March 11, 2012, 06:42:23 PM »
Worth checking the seletor drum, also the lug on the selector fork that engages with the drum
K2-K6
Reply #14 on:
March 11, 2012, 07:47:09 PM »
As the others say, it seems most likely to need access by splitting it but you should be able to do it in a day so still be up and running for the coming summer.
It does sound like an incorrect thrust washer/assembly mistake to have absolutely no engagement at all.
What happens if you try to get fith by clicking through without the engine running? can you get anything there and if so is there still no 4th when you come at it from that direction?
I know it's too late now, but I always click through the gears after assembly and before installing the motor. Just can't resist on bikes or cars as you can even feel any part engagement just using your hands.
CB750
