Author Topic: Bleedin' nipple!  (Read 3947 times)
Offline Robbo
Bleedin' nipple!
« on: March 20, 2012, 01:52:25 PM »
Went to bleed the back brake only to notice a snapped bleed screw, I though I would be clever trying to get it out with my impact driver but the bit also snapped in there so now I'm buggered...
Any ideas on fixes or other options?
there is a front caliper on the bay at the moment which I will try and get if it doesn't go for silly money
(F2 1978)
Re: Bleedin' nipple!
« Reply #1 on: March 20, 2012, 04:24:39 PM »
Heat might get the broken bit out, then when i get them from the states i will have some repair kits
Offline r1_pete
« Reply #2 on: March 21, 2012, 08:54:42 PM »
If you have access to a MIG or Arc welder, it is possible to build up a blob of weld on the broken nipple, then weld on a nut, the heat helps free things and 9 times out of 10 it will come out leaving the threads un damaged.
2009 Yamaha XJR1300 sold
1977 CB750F2 café racer project. Sold
1972 CB750K2 hot rod. Sold
and an E-Type Jaguar that considers itself worthy of all my spare cash. Sold
1971 CB450
1978 Reliant Scimitar Cosworth.
Offline kifer
« Reply #3 on: March 21, 2012, 10:22:28 PM »
Ive used the weld idea same as Pete says. I usually put a washer over and spot into hole helps me keep weld where I want it,
Good luck def worth a try!
Offline Robbo
« Reply #4 on: March 22, 2012, 09:24:47 AM »
Great idea! I'll weld it up tomorrow, in the meantime I got hold of a banjo bolt with a bleed nipple in it just incase I can't get the old nipple out
