Author Topic: CB750 oil lines  (Read 5850 times)
Offline H2Eric
CB750 oil lines
« on: March 22, 2012, 11:00:55 AM »
Does anyone know of a source for the braided oil lines that Honda originally used? I need extra lengths of the stuff for my CR750 project. Maybe there is something similar on a more modern bike, anyone know?
Eric
Re: CB750 oil lines
« Reply #1 on: March 22, 2012, 11:25:56 AM »
I just typed "braided oil lines" into the E-Bay search box and came up with nearly 400 options, so worth a try there, I'm sure artistic licence would allow you to use some of the goodrich type hoses on there available in various lengths, or there is the old type cotton braided rubber types there ;D
Offline H2Eric
Re: CB750 oil lines
« Reply #2 on: March 22, 2012, 08:05:26 PM »
I was hoping to avoid the stainless braided versions, although it's good stuff and no doubt better than the original. Lets see what flea-bay turns up.
Thanks for the tip
Eric
Offline the-chauffeur
Re: CB750 oil lines
« Reply #3 on: March 22, 2012, 08:14:37 PM »
You might struggle with OEM/original replacements, but Wemoto stock the metal sheathed braided lines.
If you get a set, you need to remove the ends from your existing lines (the bits that bolt onto the engine) and fit them into the specially manufactured end pieces on the replacements.  They look pretty neat.
Offline kifer
Re: CB750 oil lines
« Reply #4 on: March 22, 2012, 10:41:01 PM »
If you decide to go for stainless be prepared to wait, Ordered some from Wemoto 1st March just rang them another 2 weeks away, Some problem with Hel in America ? I have bought normal braided in past from car rally shops then used crimps that clamp with pincers easy to do never had any problems.
Offline Warthog1959
Re: CB750 oil lines
« Reply #5 on: March 24, 2012, 09:19:23 PM »
Check carpy's cafe racer site in the US he does metal sheathed ones in black.
Offline joeleeman
Re: CB750 oil lines
« Reply #6 on: April 06, 2012, 05:34:36 PM »
Moon pie do a set for the cr750 if your also using the oil cooler
