Author Topic: CB750F2 Crankcase Bolts  (Read 3141 times)
Offline earlybird
« on: April 03, 2012, 04:22:50 PM »
Hi
I recently picked up a broken '77 engine for a project.
It looks like someone has already had a go at it as many of the upper and lower crankcase bolts have the heads rounded off or sheared.
I can get most replaced except for the two long, M8 x 140 bolts underneath.
Can anyone give me the specifications, thread pitch etc so i can use something similar or make them myself.
Or does anyone have a couple to sell?
Your help will be much appreciated.
Offline Voxonda
Re: CB750F2 Crankcase Bolts
« Reply #1 on: April 03, 2012, 08:56:13 PM »
I know I must have these bolts lying around. Will look for you in the morning. I am in the Netherlands tho.
Cheers, Rob
Just checked and have two of them here. If you give me your adress, I will sent them to you.
Cheers, Rob
« Last Edit: April 03, 2012, 09:32:22 PM by Voxonda »
Better sorry for failing than for the lack of trying.
