Author Topic: Yoshi Kits  (Read 4167 times)
Offline Robbo
Yoshi Kits
« on: April 17, 2012, 05:00:54 PM »
Yoshi 812 kits - are they any good?
Will one for an F1 fit an F2?
Thinking about getting a spare F2 head and doing some performance mods - the F2 already is designed to rev higher than the rest of the range hence the stronger springs and different valves - are there any other changes that would make a good bit of difference?
Would it be worth upgrading clutch, cam and chains etc and are there any suitable upgrades available?
I have ordered Hondaman's book but it says it's mostly for the K range so I don't know how much help it will be with the F2
Any advice appreciated
Robbo
Offline mick
Re: Yoshi Kits
« Reply #1 on: April 17, 2012, 05:49:10 PM »
Robbo ive sent you a pm mate  ;), cheers Mick.
Offline ChrissP
Re: Yoshi Kits
« Reply #2 on: May 12, 2012, 07:09:46 PM »
Robbo, make sure you get the right pistons for the F2 as it runs a higher compression
Re: Yoshi Kits
« Reply #3 on: May 12, 2012, 08:02:34 PM »
Not the compression thats the problem it's the chamber size in the head is different (bigger) so F2 head with F1 pistons = LOW compression; F1 head with F2 pistons = BANG
Offline ChrissP
Re: Yoshi Kits
« Reply #4 on: May 13, 2012, 06:41:24 PM »
Mmmmmmm isn't that what I said you need pistons suitable for the F2
