CB750
CB750F tail light
Topic: CB750F tail light (Read 5704 times)
Galea
Newbie
CB750F tail light
June 03, 2012, 06:04:18 PM »
Looking for a tail light for a 1977 CB750F Supersport but the ones I've seen so far are unlike this one. They are either mounted by two screws or else 4 screws near the centre. The one I have is mounted by 4 screws very near the corners and it has the following code: STANLEY RR501 SAEA 71 1ATPE181 1 E 11 3246 AU40L1A JAPAN R-169
Any help, better so with part number, would be greatly appreciated. Thanks in advance.
Regards,
Joseph
Galea
Newbie
Re: CB750F tail light
June 03, 2012, 06:11:36 PM »
Close-up
Spitfire
June 03, 2012, 07:07:49 PM »
Looking at your bike it appears to be a CB750F1, initially I thought it was fitted with an F2 rear light, but a quick check in the parts manual for the F1 lists a 4 screw and a 2 screw rear light whereas the F2 manual only list a 4 screw light, so depending on where the bike was sold it could be original equipment. Here's the relevant sections of the parts manuals.
CB750F1 rear lights
This may also be handy
Last Edit: June 03, 2012, 07:11:38 PM by Spitfire
mickwinf
June 03, 2012, 07:21:33 PM »
this looks like its the same as a later 550 k3. I had a UK and a USA spec bike and the US one had the four screws nearer to the centre whereas the Uk one had them in all four corners. I might have one in the storage unit, will check. regards Mick
Galea
Newbie
June 03, 2012, 07:40:04 PM »
Thanks for your replies, the bike should be a UK one. Frame number is CB750F-1039XXX.
Mick, if you do find yours, could you check the numbers on the lense for me?
Thanks,
Joseph
Last Edit: June 03, 2012, 07:45:29 PM by Galea
archmill
SOHC Member
June 03, 2012, 11:42:20 PM »
Galea, wot! just like this one? LOL.
From the photo, numbers look the same. Will hunt it out of the boxes of parts tomorrow and let you know. Is it the full light unit or just the lense?
Archie
Galea
Newbie
June 04, 2012, 06:20:58 AM »
Hello Archmill, looks exactly like that one but we will be sure when you check the numbers. I need just the lens, what bike is it on? Do you have a part number? Thanks.
mickwinf
June 04, 2012, 05:18:55 PM »
have got one and the numbers are identical to yours, they are all printed on the centre reflector, i dont think the usa ones have the reflector. also has more numbers stanley hm-16rc-b and 39932 ch 1463004. It is in good nick how about £5 including post, regards Mick
Galea
Newbie
June 04, 2012, 05:50:17 PM »
Thanks Mick, that would be great!
PM sent.
archmill
SOHC Member
June 04, 2012, 09:30:45 PM »
Yup Galea, absolutely identical. Yours and Micks numbers are the same as this one. Part number :- 33702371602 and mine is off a 1979 'T' reg F2, so it must have been one of the last ones made.
Archmill
Galea
Newbie
Reply #10 on:
June 04, 2012, 10:48:17 PM »
Mystery solved, the case is closed
Galea
Newbie
Reply #11 on:
June 09, 2012, 06:25:39 PM »
Received the lens from Mick today, a true gentleman
CB750
CB750F tail light
