Author Topic: Carb needle heights ??  (Read 4476 times)
Offline bluemouse1006
« on: June 09, 2012, 05:54:52 PM »
Hi been on my bike today , my mate told me when he followed me my bike really smelt rich , I've replaced all the jets and needles in all 4 carbs . I have adjusted the air screws ( screwed all the way in and then out until the idle picks up ) this was about 2.5 turns out ..
I fitted the needles on the second slot from the top like the old carbs were . Any one know if this is about right ?
If I was to drop it a slot would that make it better ? Runs fine when warm but a pig when cold ( see my other topic) how far should you screw those air screws out is 2.5 too far ?
Cheers again
Amos
Amos
Re: Carb needle heights ??
« Reply #1 on: June 09, 2012, 07:23:04 PM »
I can't remember where I got this (probably from the US site) but it might help.
Den
Offline mick
« Reply #2 on: June 09, 2012, 08:24:17 PM »
Hi Amos put the clip in the middle slot & set the air screw as show on the chart Den has posted  ;), cheers Mick.
« Reply #3 on: June 11, 2012, 12:58:11 PM »
I'm going to look at the plug colour before having a task and a half stripping the carbs
Just a quick one is two slots down in the middle anyway ? It ll save me stripping if that's the case.
Thanks again
Amos
Amos
« Reply #4 on: June 11, 2012, 07:54:57 PM »
Here's a nice discusion of the subject from the US site.
http://forums.sohc4.net/index.php?topic=63177.0
Den
« Reply #5 on: July 06, 2012, 09:00:03 PM »
Stripped my carbs again and set the needles to the middle ,
Sinced the carbs with gauges and set the bleed screws to 1 turn out ..
Starts from cold a lot better and runs well sweet now . What a difference it's a joy to ride now ( should be as I've replaced everything for new ) its like triggers broom !!!
Cheers Amos
Amos
Offline mick
« Reply #6 on: July 06, 2012, 09:06:53 PM »
Nice  cyril  8)
« Reply #7 on: July 07, 2012, 12:09:16 PM »
Glad to hear that it turned out right.
Den
