Author Topic: fuel octane and final rejetting / pics!!!!  (Read 4947 times)
Offline jcknapp
« on: June 19, 2012, 12:38:37 AM »
Hello all-
     Well I have finally started and finishing up dialing my bike. Got 115's in the main and 40's in the pilot. So far so good except for the flat spot I am getting around high 2 and low 3. Anyone? Otherwise runs perfect. Rebuilt pretty much everything, replaced a bunch of junk and shed off alot of the weight. Also does anyone use high octane fuel in their cycles? I use regular now because I heard the low compression engines are not good for high octane fuel. Anyone else hear of this? Thanks and enjoy the pics.
J-
TON UP!!!
Offline LesterPiglet
  • 1977 CB550F2
Re: fuel octane and final rejetting / pics!!!!
« Reply #1 on: June 19, 2012, 01:15:44 AM »
No idea about your jetting. I just use supermarket fuel.
Can you post a pic of your gauges please?
Offline jcknapp
« Reply #2 on: June 19, 2012, 02:53:48 AM »
here ya go lester. cheers  Notice (in black and white) the two egg shaped pieces of wood on the triple tree. I custom made them to cover the ground down old bar holders. Made of Padouk.
j
« Last Edit: June 19, 2012, 02:55:26 AM by jcknapp »
TON UP!!!
« Reply #3 on: June 19, 2012, 07:47:55 AM »
All these bikes were designed to use unleaded low octane fuel from the outset. Only the tuned bikes needed higher octane.
I use 95 (UK) in all of my bikes be they old carb Hondas or modern FI Triumphs.
US Octane is different though (UK: low = 95, high/super = 98)  Wikipedia has a good write-up on it.
