Fix that rattling cam chain, be warned
Topic: Fix that rattling cam chain, be warned (Read 11988 times)
daz
SOHC Associate
June 24, 2012, 03:24:49 PM »
Hi all, bike made a funny noise & broke down, had to be recovered home. Got to work on the engine today, found all the exhaust valves have hit the pistons & the static cam chain guide has broken in half.
Found the offer half wrapped around the crank between the cam chain sprocket & hivo sprocket.
Did manage to bash it off, also found 2 oil ways for the camshaft had bits of old o ring in, here are some pics, cheers Darren
Last Edit: June 24, 2012, 05:00:31 PM by daz
Honda CB 550K0 1974, Honda CB500X 2020
daz
SOHC Associate
Re: Fix that rattling cam chain, be warned
June 24, 2012, 03:40:56 PM »
2 small pieces of what look like o ring stuck in the camshaft oil ways.
Last Edit: July 03, 2012, 02:01:32 PM by daz
LesterPiglet
1977 CB550F2
June 24, 2012, 05:31:09 PM »
Damn bad luck. Are the valves damaged?
hairygit
June 24, 2012, 07:42:04 PM »
Sadly, bent valves are almost guaranteed
daz
SOHC Associate
July 03, 2012, 12:36:32 PM »
Bummer valves are bent, guides look ok, no cracks.
I do have 2 spare 500 four heads, can i take the exhaust valves from them? cheers Darren
Last Edit: July 03, 2012, 02:03:30 PM by daz
daz
SOHC Associate
July 07, 2013, 05:10:40 PM »
My bike is back on the road, at last, finished putting it back together last night & MOT done this morning, yes on a Sunday.
Went for a 80 mile ride to bed the new rings in, she runs well
Last Edit: July 07, 2013, 05:15:37 PM by daz
LesterPiglet
1977 CB550F2
July 07, 2013, 05:55:11 PM »
Nice weather for it.
July 08, 2013, 08:56:04 AM »
Those bits of O ring are far too big to have come upwards through the restrictors, only place i can think of is bits from the cam cover O ring joint
July 08, 2013, 10:09:21 AM »
just as an aside if that was mine i would be doing an oil change every 500 miles till 1500 then back to marmal Plus you can check oil flow in two ways:-
(1) remove the tappet caps and shine a torch in
(2) if you remove the end caps and loosen the bolt that holds down the steel bracket oil should pee out of there at quite a rate.
You repaired it quickly and well, Did you fit a new cam chain? and what state was the tensioner in, I will be honest and say I have seen a couple of badly worn front cushions but thats all---It was in the right way round wasn't it(inside the chain run) as if the chain is well mullered it can be fitted backwards and still get the chain on the sprocket
daz
SOHC Associate
July 08, 2013, 05:49:23 PM »
Hi Byranj, not sure where the bits of o ring came from but both o rings where missing from the head gasket oil ways, the base gasket o rings where still there. Before i put the rocker on i made sure oil was pumping up to the cam shaft.
New cam chain (soft link), 4 x second hand exhaust valves vgc, new static cam chain guide, new tensioner blade, (tensioner undamaged) new rings, honed barrels, new gasket set, new oil & filter.
I used alloy wheel cleaner in the end on the head as it is so fiddly to clean.
Yes i agree i will change oil as you say, thanks for your advice, all the best Daz.
I found this chaps videos helpful
http://www.youtube.com/user/SocoMoto707
Reply #10 on:
July 08, 2013, 06:26:36 PM »
Well It must be possible for those O rings to do that as it happened to you but I will say that that is an absolute first mate
daz
SOHC Associate
Reply #11 on:
July 08, 2013, 06:35:12 PM »
Still not sure myself that is what happened, just glad oil managed to get past the blockage as this is the 1st time since i owned it that the engine has been apart, 14 years & aprox 30,000 miles
matthewmosse
Reply #12 on:
July 12, 2013, 05:03:05 PM »
I've seen those o rings do that once- i think on my first 550. worse is when the tensioner lets go. I had one like the one in this thread. Bent valves. Alarmingly it did it again within months. I bought another where it had wrapped itself round the gear clusters destroying the whole gearbox effectively.
