Author Topic: front wheel locking  (Read 12707 times)
Offline LesterPiglet
  • 1977 CB550F2
Re: front wheel locking
« Reply #15 on: August 21, 2012, 09:30:18 PM »
Have you cleaned out the fluid return in the master cylinder? If this is blocked it will not let the pads return.
Offline steff750
  • THE POWER OF DREAMS
« Reply #16 on: August 21, 2012, 10:40:37 PM »
Quote
Still having problems with the front brake binding. the brake leaver is tight no play as soon as you touch the brake is on. when stationary it will not roll forward or backward.
 :-\  have you changed the front brake lever,because you must have play on the brake lever i cant recall the exact measurement,i have several spare levers and some have more freeplay than others,if there is not enough freeplay on the lever it will cause the brakes to bind and boil the oil.it must not be touching the master cylinder plunger and should return freely,failing that are you sure the circlip is fully home,in anycase remove lever and then try and rotate the wheel, just in case that's your problem. BTW i also changed my wheel bearings when bike was pull backwards on left hand full lock the wheel was binding, and yes new bearings cured that.
Offline Waggles
« Reply #17 on: August 22, 2012, 07:10:42 AM »
See my earlier post, is caliper mounted correctly and true to the disc? also, is the caliper arm pivot seized? finally, are new pads correct size? if they are too thick it will never release.
I assume you cleaned out the caliper seal groove ( they are often bunged up with crud which causes seal to seal too well and not let piston move )
Offline billy192
    • Shermonkel
« Reply #18 on: August 22, 2012, 11:03:31 AM »
yes there was play before i fitted new seals
and yes i did clean out the caliper seal grove
and also yes the mudguard bracket is in the correct place.
 not touched the master cylinder,
where is this fluid return? do i have to renew all the seals in the master?
thanks for all the ideas, i am sure i will get there with your help.
billy
Billy
  • 1977 CB550F2
« Reply #19 on: August 22, 2012, 11:39:47 AM »
The fluid return is inside the master cylinder. There are two holes in there, it is the smaller one.
« Reply #20 on: August 22, 2012, 01:39:23 PM »
Yeah Lesterpiglet is right when it works good watch out for the fluid squirting out like a geyser take your tank off.
Bitsa
Offline billy192
    • Shermonkel
« Reply #21 on: August 26, 2012, 08:46:56 PM »
Hi Lesterpiglet
the hole to the left is clean but the hole to the right seems blocked.
how small is this hole? Is it sewing needle size or can i buy a fine drill bit?
Billy
Offline mickwinf
« Reply #22 on: August 26, 2012, 10:46:50 PM »
the hole is tiny, i used a drillbit used for modeling, was 0.3 mm!
« Reply #23 on: August 27, 2012, 06:35:20 AM »
Two strads of copper wire from a speaker cable twisted together is about the size, or in other words TINY
Offline the-chauffeur
« Reply #24 on: August 27, 2012, 11:09:55 AM »
If the brake is still binding under weight but not when the front wheel is raised - and bearing in mind all the other stuff you've checked, I'd be looking at two things - the brake caliper pivot pin and the fork oil levels.
The pivot pin is well know for seizing, and if it does it won't allow the calliper to float.  That won't help.
Failing that,you may well find one (or both) fork oil levels are low, which would cause the front wheel to be unbalanced when under weight.
HTH
Offline billy192
    • Shermonkel
« Reply #25 on: August 27, 2012, 08:34:36 PM »
Thanks to all,
the 0.3 drill did the trick it worked a treat breaks are now perfect. No binding and i can wheel it back and forth with ease well it is a 500lb bike.
thanks
Billy
Billy
Offline billy192
    • Shermonkel
« Reply #26 on: September 01, 2012, 08:54:21 PM »
Bike goes great, it must have been binding a lot as now it takes far less revs to move off. great
Billy
 ;D ;D ;D ;D ;D ;D ;D ;D
Billy
