Author Topic: head stuck  (Read 3391 times)
Offline Robbo
head stuck
« on: July 12, 2012, 09:08:18 PM »
my head is stuck to the barrels on my f2... I've undone all the bolts and the barrels have lifted from the engine. I am baffled (unless there are 4 more bolts under the 4 rubber pucks?)
tried knocking it with a rubber mallet, soaking it in wd40, going to attack it with wooden wedges tmw but am really struggling
Any help/advice welcomed
Re: head stuck
« Reply #1 on: July 12, 2012, 09:21:35 PM »
Yes, there ARE 4 more crosshead screws (unless they've been replaced with bolts by a previous owner) under the rubber plugs/pucks. So don't try wedges etc until you have got them ou, they are quite deeply recessed, so make sure you have a long screwdriver, and make sure it is the correct fit for the heads :D
Re: head stuck
« Reply #2 on: July 13, 2012, 08:07:26 AM »
They have a 10mm hex with a screwdriver cross in the middle
