Author Topic: Oil pressure switch  (Read 4346 times)
Offline StPeter
Oil pressure switch
« on: July 30, 2012, 02:47:07 PM »
An alternative to the expensive OE switch:
http://www.hewisclassicspares.co.uk/oil-pressure-switch-rover-600-800-sterling-triumph-acclaim/
You'll need a couple of M10 washers to lift the body clear of the oil pump.
I used these: http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=261073143690
I also retained the hex screw on the wiring connector 'cos it's easier to tighten.
1975 CB500
Tiger 1050
