Author Topic: Wiring diagram/instructions after market rectifier etc  (Read 5402 times)
Offline bluemouse1006
« on: August 04, 2012, 05:34:20 PM »
Hi
Im looking at replacing my rectifier etc on my K5 ( eBay Number 120959950835) anyone bought such a thing ? There is a plug that looks like it just plugs in but then it has two diode type wires where do they go ??
Anyone got any instructions for such a thing ..
Part on eBay is half the price of any I've seen !!!!
Amos
Amos
Offline the-chauffeur
Re: Wiring diagram/instructions after market rectifier etc
« Reply #1 on: August 04, 2012, 07:54:08 PM »
Amos
That unit is wired to work with bikes with a separate regulator and rectifier.
When my K2 left the factory, it had both units - the original rectifier was fitted with the plastic connector; the regulator connected to the loom by means of three wires with female spade connectors on the ends (white, black and green).  The unit on eBay takes place of both those bits, leaving just a green (earth) wire from the loom.
I've replaced my two with a unit that's very similar to the one in the advert, but I got mine from Silver's - and yes, it was about twice the price of the one on eBay.  I dunno what the wiring arrangement on the K5's is like, but the modern solid state replacement is far more reliable (for me) than the original - it also doesn't require any adjustment (the original regulator can be adjusted).
The one drawback is that it's not a simple bolt-on job because of the battery tray design.  Again, I dunno what the K5 is like, but the K2 has a captive bolt that holds a sub-assembly on to the side.  I took the sub-assembly off, drilled the captive bolt out, drilled a second hole and put my own bolts through the tray from the inside.
I dunno whether you can see what I mean from this:
 . . . or this . . .
(ignore the relays - they're installed to take the weight off the headlight switches, but I need to fit them properly)
« Reply #2 on: August 04, 2012, 09:33:06 PM »
Use the contact seller link and ask if it comes with full instructions/diagram. If not walk away.
I suspect the white goes to one of the reg wires and maybe the black as well but no guarantee on that
« Reply #3 on: August 04, 2012, 09:35:07 PM »
Sorry - yeah - that was what I was trying to say . . .
 . . . the black and white wires go to the regulator connectors in the loom.  Everything else is contained in the plastic plug.
« Reply #4 on: August 06, 2012, 12:21:08 AM »
Anyone got instructions for one of these ? You can scan and put on the site . I've contacted the seller but they don't have any instructions as they are able to be fitted to several different bikes.
Mine will plug into the big white plug buts where the other two wires go and which way round !!!
Amos
Amos
Offline Green1
« Reply #5 on: August 11, 2012, 11:19:04 PM »
Hi I to have replaced my rectifier what did you do with the earth from the regulator as I have just left mine lose.
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Triumph tiger 800
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
« Reply #6 on: August 13, 2012, 03:50:52 PM »
Not bought one yet but will let u know
Amos
Amos
