Author Topic: cb900 pistons  (Read 3634 times)
Offline rooky
cb900 pistons
« on: August 06, 2012, 08:51:18 PM »
hi
i am thinking of using 900 pistons in my 750
my question is how do i deal with the fact that the piston crown is 1.5 mm higher than the 750
i am thinking of putting a spacer under the barrels but how thick should it be
also is there a worthwhile performance increase from using the later (k7/f2) carbs
cheers
rooky
Offline steff750
  • THE POWER OF DREAMS
Re: cb900 pistons
« Reply #1 on: August 06, 2012, 10:41:37 PM »
 :o i was told this years ago by a anorak friend we all got em ,that you could fit 900 pistons into a 750 just to increase compression, but i would not like to try it myself.your best bet is asking someone who has already done it,i have a f2 engine and carbs on my sidecar unit , the only real difference is these carbs have an accelerator pump and considering the extra weight of the chair, they pull very cleanly through the gears with no hint of getting bogged down, my advice would be, forget the 900 pistons unless they are really cheap and the engine is already stripped down ,but i would certainly try the f2 carbs, come to think of it perhaps a f2 engine might be a better option. ;)
Offline rooky
Re: cb900 pistons
« Reply #2 on: August 06, 2012, 11:12:54 PM »
i do have the 900 pistons and the engine needs a rebore so i'm not loosing anything
if it will work
