Author Topic: Mechanical (Piston valve) or Constant velocity carbs  (Read 3572 times)
Offline M0WBY
« on: September 25, 2012, 07:01:21 PM »
Hi
Which are better Mechanical (Piston valve) or constant velocity carbs on a CB650?
I know the CV carbs are found on the later models and have mahosive main jets compared to the older mechanical carbs (92 vs 120).
But does later = better? Better performance? Better durability?
I know the older ones you can set the float height but the CV ones are fixed level floats.
Just wondering...
John
John Willby
M0WBY
Slack jawed knuckle dragging Northamptonshire peasant labourers since c.1670
Re: Mechanical (Piston valve) or Constant velocity carbs
« Reply #1 on: September 26, 2012, 06:35:16 AM »
Not 100% sure but i dont think you can just swop carbs as the spacing is different
Offline M0WBY
« Reply #2 on: September 26, 2012, 07:52:28 AM »
Hi
I was not thinking of changing to them I was just wondering why they changed them. Just idle speculation... usually they had a good reason for changing stuff!
John
John Willby
M0WBY
« Reply #3 on: September 26, 2012, 04:17:19 PM »
Emissions for the US i think
