Author Topic: Clutch switch ??  (Read 4633 times)
Offline cb750stu
Clutch switch ??
« on: October 08, 2012, 11:45:40 AM »
Hi Folks,
Just wondering do i need the clutch switch to make everything run right ??
My switch wire has snapped where it goes into the lever housing leaving a white plastic piece inside,how does this come out ???
Just wondering,
Stu !!!
1976 CB750 F1 SS in bits !!! but getting there
Offline Waggles
Re: Clutch switch ??
« Reply #1 on: October 08, 2012, 01:21:39 PM »
Hi Stu,
In theory you don't need the clutch switch but its a safety feature and stops the electric starter from working when you are in gear ( always good for a laugh ) If you are happy with that ( I personally would prefer to keep it ) then you can do without. Can't remember off the top of my head whether the switch is normally open or closed but you would either short the two wires together or insulate them apart to make it all work depending on which it is.
Sorry have never taken one of these out, someone who has will doubtless be along soon
« Reply #2 on: October 08, 2012, 03:44:52 PM »
Remove the lever blade and push from the outside towards the lever, wires need to be twisted together to start without neutral light on
Offline cb750stu
« Reply #3 on: October 08, 2012, 08:05:10 PM »
Cheers for the info guys is this the right replacement part ???
http://www.davidsilverspares.co.uk/CB750F1-(Single-overhead-cam)/part_7002/
Offline Waggles
« Reply #4 on: October 09, 2012, 07:18:15 AM »
Yep, thats the one
« Reply #5 on: October 09, 2012, 08:08:29 AM »
It is but you may find it cheaper to get a brake light switch off a drum braked small bike like the CG 125 as they are made pattern and the only difference is the wire colour
Offline Waggles
« Reply #6 on: October 10, 2012, 07:12:10 AM »
Thats why you are a Guru Bryan and Dave Silver dines out on my salary!  ;D
« Reply #7 on: October 10, 2012, 03:57:56 PM »
Don't you worry about that mate, DS has had a lot of my cash over the years, once went down with a beavertail and came back with 5 bikes---one of which i had to buy to prise the NOS tacho from his hand!!!
Offline Waggles
« Reply #8 on: October 11, 2012, 07:07:09 AM »
Guess we are all shareholders.......
