Author Topic: Wheel hub distance collar,which way does it go ???  (Read 2945 times)
Offline cb750stu
« on: November 24, 2012, 12:17:06 PM »
Hi Folks just wondering if there was a specific way that the distance collar in the hubs goes it is seems slightly different at either end ???
This part
http://www.cmsnl.com/honda-cb750f1-super-sport-1976-england_model14680/collar-distance_42620392000/
Regards
Stuart
1976 CB750 F1 SS in bits !!! but getting there
Offline cb750stu
Re: Wheel hub distance collar,which way does it go ???
« Reply #1 on: November 25, 2012, 09:58:21 PM »
Any ideas ?? Its so I can crack on with building up my wheels !!!
Regards Stuart
Offline Seamus
« Reply #2 on: November 26, 2012, 10:24:28 AM »
I would imagine that it makes no difference. The outer tangs are just to centre the spacer in the wheel.
Hope that makes sense
« Reply #3 on: November 26, 2012, 01:16:54 PM »
I guess if you don't get much response it would suggest that others aren't sure either. And it's an area that not many people see or work on.
I would start by offering the ends up to each of the bearings that it's going between to see if there is any clearance issues with the bearing cage etc that would cause damage.......then try to assembly the bearing and spacer pack onto the wheel spindle without the wheel present so that you can take a look at what will happen inside the hub ( you may have to space the spindle to centralize the "spacer" with some tape or similar) and see how or if it assembles without and clashes.
Offline cb750stu
« Reply #4 on: November 27, 2012, 08:55:55 AM »
Cheers Guys i managed to figure out which way it goes by looking at a schematic of the wheels,bearings went in fine after a few hours in the freezer,
Stuart
