CB750
swinging arm grief
Topic: swinging arm grief (Read 5391 times)
gasman
Newbie
swinging arm grief
November 29, 2012, 10:31:09 PM »
Hi Guys
Need some help-- imported a k5 from the states, complete strip down ongoing, have a problem with s/arm. Removed the s/arm which had roller bearings in place, took them out [infact they fell apart] went to replace them with some brass bushes which seems to be the way to go. Went to insert the collar over the spindle-- its a bit slack when inserted into the bushes. Cant find an answer, anyone had a similar prob. Big Help please
Re: swinging arm grief
November 30, 2012, 07:11:50 AM »
If you used the collar that was with the rollers it is the wrong size for bushes, you will need the proper Honda one.
now some of the later ones have been discontinued but you can fit the earlier one, just sit down when you check the price.
Also GREASE EVERY YEAR OR 1,500 MILES
Bitsa (Ralph Wright - RIP)
November 30, 2012, 10:36:29 AM »
If Bryanj is correct with using an earlier one they are available unlike the k6s.I have found two on eBay 220538435391 59 euros 181029288545 48 euros cmnsl 54.50 and DS 49 SQUID+TAX.
Does anybody know what the difference is?
Bitsa
November 30, 2012, 12:34:03 PM »
There are scrolls machined on the outer diameter at both ends of the early one and a hole at each end throgh the wall for grease to get through, whilst the later ones have no scroll just a groove and hole.
November 30, 2012, 01:36:47 PM »
Thanks for the info Bryanj.On my k2 the grease nipples was on both ends of the main bolt which in my view was the best on the later ones the nipple is located halfway along the arm and arkward so is this the reason they re engineered it to make it better?Can I convert it back to the k2 way if I can get the main bolt?
Bitsa
November 30, 2012, 06:22:45 PM »
Yes Mate, if you can get the bolt. Unless you are anal about originality drill and tap the ends 6mm and fit better nipples than the push in honda ones
November 30, 2012, 07:07:14 PM »
Brillant Bryanj I can get hold an original bolt and yes I am anal and thinking how long have I got left after my bruv died this month only a bit older than me and would love the bike to be as I remembered.This month bought loads of new bits and have decided to restore all again as its so frackin boring here in the winter.So its classsic gold radio and lots of grunting going on in the workshop.Only doing this for something to do and I still have a dribble of oil leaking down between 2 and 3 cylinders not the head gasket.
Appreciate your knowledge
Bitsa
SteveD CB500K0
Administrator
Ride on the Steel Breeze...
swinging arm grief
November 30, 2012, 07:14:19 PM »
Classic Gold in France. That must be online?
I lived in Germany for a while in the late 80s. Their TV and radio was dreadful. VoA was the only English language station. No satellite in those days.
Thankfully my boss saw sense and sent me back to the UK after a couple of months.
Last Edit: November 30, 2012, 07:28:59 PM by SteveD CB500F
tom400f
November 30, 2012, 08:01:19 PM »
Sorry to hear of your loss bitsa and wishing you all the best
1978 CB400F2 Yellow
1997 VFR750FV Lapis Blue
2010 VFR800 A9 Silver
2013 Yamaha FZ8 Grey (Son's)
December 01, 2012, 12:52:00 PM »
Thanks for that tom400f but I should have said capital classic gold of Astra sat.
Many thanks to all
Bitsa
gasman
Newbie
Reply #10 on:
December 05, 2012, 09:53:47 PM »
Hi Guys
Thanks for the info guys, have found the forum brilliant, ordered a centre bush from holland, and yeah I sat down whilst paying for it, why so expensive?Having also just purchased a cbx from the states, [as well as my two cb750s] I am told it is now more viable to break these bikes and sell as spares. Will this reflect on used prices?
regards neal
CB750
swinging arm grief
