Author Topic: Clutch lever and perch ??  (Read 3095 times)
Offline cb750stu
« on: December 17, 2012, 10:12:54 PM »
Hi Folks
I am going to be running with no switch gear on my bars just a start/stop and horn button,my clutch side has the switches built into the perch,
I was wondering if anyone knew if any other Honda model just has the perch with no switches built in ???
And also if a 750 clutch lever would fit ??
Regards
Stuart
1976 CB750 F1 SS in bits !!! but getting there
Offline Seamus
Re: Clutch lever and perch ??
« Reply #1 on: December 17, 2012, 11:48:42 PM »
Can you not use a lever with the same diameter bars? There must be a good few around
Offline cb750stu
« Reply #2 on: December 18, 2012, 09:43:48 AM »
Hi Seamus thanks !!!
I've managed to source one from the States which will take the lever and cable !!!
Ordered a few more bits aswell
