Author Topic: Rockerbox Gasket  (Read 7642 times)
Offline Green1
Re: Rockerbox Gasket
« Reply #15 on: August 15, 2013, 09:45:41 PM »
Hi Bitsa good to see you found it.
It funny I've been using the Triumph the last couple of weeks and had exactly the same thing
I noticed oil on my boot looked at the back of the engine to find oil over everything :o So I decided it was the rocker cover gasket so I striped the bike down thinking it was going to an easy fix only to find I had to drop the engine so no biggie remove rad,exhaust and a couple engine mount bolts whats hard about that.So with the luck I have it goes wrong almost instantly I undone a couple of studs with ease the third one ping snapped instantly So a trip to the dealers.I come back seal the rocker cover place the engine back in and ping the engine mount bolt striped it's thread.So two days later back down the dealers come back push the bolt in I can't find a nut to fit ??? anyway I've used it this week no leaks until to day I pulled away it's like a two stroke blue smoke so just pulled it apart again to find the air filter box full of oil so a bit of head scratching I noticed oil drip from the crankcase breather BINGO found it the breather seal split.
Regards Thread hijacker  ;D
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Triumph tiger 800
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
Offline Yoshi823
  • Biker to the bone...
« Reply #16 on: September 04, 2013, 10:51:03 AM »
As others have suggested, a thin smear of Blue Hylomar is a good idea. I've been using this stuff for over 38 years of engine building & have never had any problems & still use the stuff for many modern engines.
Bikes...they're in the blood.
Yamaha R1 2001
Yamaha FZR1000R EXUP 1990
KTM 450 EXC RFS 2004
Honda XR400R 1997
Honda CB125T2 1980
Yamaha FJ1200 3XW 1991
