CB350/400
Neutral switch connection
Topic: Neutral switch connection (Read 5970 times)
Seamus
April 09, 2013, 06:00:12 PM »
Silly question but how does the wire attach to the switch?
Received a 400/4 in parts to assemble and I did not take it apart. Wondering if something is missing.
Thanks in advance
hairygit
Re: Neutral switch connection
April 09, 2013, 06:04:09 PM »
There should be a little tiny (easily lost!
) bolt in the top of it, and the single wire has an eye terminal on it, which is held by the bolt
Seamus
April 09, 2013, 07:02:12 PM »
Thanks mate. Appreciate the quick reply. Is the bolt a phillips type head screw?
PS do you still want the barrels?
steven400/4
SOHC Expert
April 09, 2013, 08:33:48 PM »
mine has a spring witch you push down then put your wire in the hole let spring go and it holds it in place
cb400f2 x7
honda ss 50
gsx 1400
Seamus
April 09, 2013, 11:13:33 PM »
Thanks Steven, I will have a closer loook tomorrow and see which type I have. (Guess there are two). The wire to mine does not have a loop to fit a screw, so possibly the same as yours. (I hope so as I dont have the screw)
Seamus
April 10, 2013, 04:21:16 PM »
Correct for your type Steven. Poked it through the little hole under the spring. Thanks for the heads up on that one.
steven400/4
SOHC Expert
April 10, 2013, 05:23:03 PM »
no problem mate
cb400f2 x7
honda ss 50
gsx 1400
CB350/400
