Author Topic: 400four choke  (Read 20015 times)
Offline yorky10
Re: 400four choke
« Reply #15 on: May 07, 2013, 07:38:05 AM »
can any one tell me where I can get a good exploded picture of fourhundred 4 carbs.please.my book picture,haynes and the American one are oiled up .sad is not.if its not running after this its for sale.yorky.
hi im a pensioner from Derbyshire,been into bikes since of age of 10 ish never been with out one.at present doing a 1976 400four from bin bags and boxes.getting there slowly.yorky10
Offline mickwinf
Re: 400four choke
« Reply #16 on: May 07, 2013, 10:06:19 AM »
Try the CMSL site as they have exploded diagrams of everything. I have been where you are, frustrated with a bike that won't play ball, but keep trying and with help from this forum you will get there! Is there any members nearby who could take a look, two heads are better than one! Also everything else has to be spot on, valve/ignition plugs etc. Good luck!! Mick
Offline sweetpeauk
CB400F
CB400F2
RVF400
XT500D
CB900F2C
GS1000GT
XS1100E
Offline Dan
Re: 400four choke
« Reply #18 on: May 07, 2013, 05:27:39 PM »
Only running when on choke definitely sounds like blocked jets. I also had carb issues (bike wouldn't rev past 6000). I know this will be frowned upon by some people but as well as using carb cleaner I ran a thin wire through the emulsion tubes with them out the carbs - down the length of them and through the holes drilled across them. If you use a soft wire, copper for example, rather than something coarse like untwisted brake cable there shouldn't be a problem. It worked for me...
1994 GSXR750WR Endurance rep
1975 CB400F ongoing project
Offline mickwinf
Re: 400four choke
« Reply #19 on: May 07, 2013, 05:44:20 PM »
Did you remove the emulsion tubes to clean them?
Offline Dan
Re: 400four choke
« Reply #20 on: May 07, 2013, 10:52:33 PM »
Yes, and the jets. They just unscrew and you can put a good squirt of carb cleaner into the internal drillings of the carbs while they are out.
Offline ewanhughes
Re: 400four choke
« Reply #21 on: May 09, 2013, 09:36:42 AM »
Hi Yorky, have you seen the document that Tim Boughen has produced?  It's basically a complete run through of the process of disassembling, cleaning and replacing 400/4 carbs.  It's mainly done with pictures and I can honesty say I wouldn't have had the confidence to tear my carbs apart if I hadn't seen it first.  I really is that good!  See link below.
http://www.docstoc.com/docs/97200467/CARB-REBUILD-101
All the best and god luck.
Kenny
Offline mattsz
Re: 400four choke
« Reply #22 on: January 18, 2019, 12:11:53 PM »
Old thread, I know... I've seen many references to Mr. Boughen's document, but it seems to have disappeared from the net.  Does anyone have a source?  Or, does anyone have a copy available?
Re: 400four choke
« Reply #23 on: January 18, 2019, 12:39:43 PM »
I have it but it's too large to attach.
Pm me your email address and I will send it to you. :)
Offline mattsz
Re: 400four choke
« Reply #24 on: January 18, 2019, 12:56:29 PM »
PM sent, thanks!
Re: 400four choke
« Reply #25 on: January 18, 2019, 12:58:07 PM »
PM sent, thanks!
Done
Re: 400four choke
« Reply #26 on: January 18, 2019, 01:10:21 PM »
Done Andy
Anyone else  ;D
Offline Andych
Re: 400four choke
« Reply #27 on: January 18, 2019, 10:58:49 PM »
Perfect.. many thanks :)
1975 CB400 - Project
1978 Yamaha SRX250 - Project
Offline mattsz
Re: 400four choke
« Reply #28 on: January 19, 2019, 10:21:30 AM »
The US sohc forum has larger size limits, I was able to post it there...
http://forums.sohc4.net/index.php/topic,152810.msg2045081.html#msg2045081
