Author Topic: Hi folks !!  (Read 5288 times)
Offline Thedodge
  • Always wanted a 400 four since I was a kid !!
Hi folks !!
« on: May 27, 2013, 09:32:52 AM »
Hi everybody. Just bought a 400 four on which a restoration was started by the P.O. Everything he has done so far is to a very good standard. The frame and all other relevant parts(brackets, air box, yokes etc)have been cleaned and powder coated. The wheels have been rebuilt with original hubs, new rims and spokes. The sides cases from the motor have been highly polished. Seat refurbished as original. The list goes on. I have a few questions for now, I'm sure there will be more. Firstly, the air box seems to be mounted using 3 grommets. Are they all identical or is the lower one different. Secondly, does the brake line from the master cylinder to the "y" piece on the lower yoke route in front or behind the top yoke. One of the banjo unions on this short line is cranked and the other one is straight. Which goes where?  Finally ( for the time being) does the rear light and number plate bracket mount onto the rear mudguard using rubber mounts or does it bolt directly onto the mudguard?
Offline tom400f
Re: Hi folks !!
« Reply #1 on: June 03, 2013, 09:18:03 AM »
Hi and welcome
Sorry no one has replied :-/ we're not like that at all really :-)
I'll post some pics for you later. The front brake union is a bit tricky - I remounted this over the winter and the Haynes manual doesn't really show it too well... In the mean time - how about some pictures of your bike?
1978 CB400F2 Yellow
1997 VFR750FV Lapis Blue
2010 VFR800 A9 Silver
2013 Yamaha FZ8 Grey (Son's)
Offline tom400f
Re: Hi folks !!
« Reply #2 on: June 09, 2013, 06:31:24 PM »
Hope these help. The rear light has rubber mounts with metal sleeves inside.
Here's the airbox from the parts list...
Hope its not too late after all this time  :P
1978 CB400F2 Yellow
