CB350/400
What a Shame..!!
Topic: What a Shame..!! (Read 21005 times)
PatM
SOHC Member
2001 R1, Triumph 1200 and the little 400/4!
Re: What a Shame..!!
Reply #15 on:
June 19, 2013, 09:52:38 PM »
I agree with the speed scenario- mine got considerably more mileage that yours and its been stripped many time- it like lots of revs and whips up to 70 quite easily- but that's enough for a 35-year old girl- I don't want something falling off or dropping. Off for MOT tomorrow as done enough fettling and need to ride it legally :-) Ive a few newer bikes to ride that will take more of a thrashing.
400/4s do like revs and mines ok on tick-over, a slight hesitation below 3k and bloody marvellous over that - I don't take it over 7.5k
Very amusing reading the re-build- nothing ever goes smoothly , especially carbs and fuel.
z1100r
SOHC Member
Reply #16 on:
June 20, 2013, 09:38:14 AM »
You are right there...!!!
Got all the bits from Silvers - after another trip to FEDex building cos i wasn't in for delivery pain in the ass - and fitted everything within 30 mins. Zoomed off out for a ride but its still not right. Its not bad but I remember the 400's Ive ridden in the past being super smooth with perfect carburation if they had original airbox. This has a noticeable glitch on initial pick up. I wasn't happy with it so carbs are off again. There is definately still a problem somewhere most likely in the primary circuit.
Everything else is done, I filled it up with fuel last night and came out from paying to a little gathering that had formed around it. Had a 10 minute laugh and a joke about the old days with some guys that obviously remembered their 400's very fondly. I never actually owned a 400 four I was always a 2-stroke nut (still am).
So the carbs are on my bench AGAIN. Initially they were very bad and as such I went over and over them but I must of missed something. Doh. All good fun eh. What else would I be doing - "couch potatoeing".
Last Edit: June 20, 2013, 09:52:17 AM by z1100r
PatM
SOHC Member
Reply #17 on:
June 20, 2013, 11:35:14 AM »
Well, mine passed its MOT but I have to admit- my one ALSO has a slight hesitation picking up- its ok after 2.5k- so ill be interested to read if you nail the problem.
Ive another set of carbs I used a month ago- stripped, completely re-jetted using kits- the only thing I didn't do was separate them- so I still have some O rings left over. The bike DIDNT like them- far worse hesitation and an annoying tick-over drift like they were leaning out- would drift on tickover up to 2k, then settle after a blip. I have a balance between the set that's on there which are a bitch to start from cold- and the other set with the poor running.
Hey Ho- keeps us off the streets but in the wifes bad books with the smell of petrol in the air over the house of a weekend!
z1100r
SOHC Member
Reply #18 on:
June 20, 2013, 03:49:47 PM »
Well in both our cases there is a blocked hole somewhere. This one doesn't settle to Idle correctly either. It revs high for a while sometimes before plummeting to stall. I know what this is and have fixed it loads of times in the past but I cant remember at the moment. Hahaha. I'll think of it later. Its basically lean on the primary circuit. must check how the fuel is supplied via that circuit, (wether its a small hole in the bottom of the venturi etc). I did rely on my airline cleaning these passages (maybe it didn't).
PatM
SOHC Member
Reply #19 on:
June 20, 2013, 04:01:12 PM »
Yep. did the same and plenty of carb-cleaner- some ended up in my face due to the over-exuberant use of the air-line. Carbs are great when they are working but not so great when they are 35 years old.
z1100r
SOHC Member
Reply #20 on:
June 21, 2013, 09:17:18 AM »
Well I got that wrong....It was seriously rich on the primary circuit not lean. I still dont know why. 2 turns on the air screw as my manual suggests leaves it 'hunting' away with sooty black plugs. 3 turns and its settled down to a nice throttle response, even tickover, and much cleaner plugs.
I noticed when running it on my plastic bottle that as the fuel runs out (less in float bowls) it switched from eratic and lumpy to running lovely. Float heights are set at 21mm as manual. Its a strange problem. When cold the bike ran great, no choke was ever neede though. It all suggests a blockage in the air feed to the mixture screws, but i cant find any problem.
Turn your fuel off and see if yours improves (cleans up) as the petrol runs out (after say a minute on tickover). Makes a huge difference to this one. Suddenly it will purr at 800-1000 rev perfectly. Turn the fuel back on and it starts the lumpy horibleness again after a short while. The weird thing is that its all 4 cylinders affected exactly the same. I could accept one carb having an issue but not all 4 with exactly the same problem. It like someone has put a pin hole in all the floats. haha
I've not bothered connecting any throttle cables or airbox rubbers while I sort this so I can get them on and off quick. They are off again this afternoon for a final inspection and to set float heights to 22mm.
At one point last night an awful lot of 'steam' was comming from the engine breather, mind you I had had it on tickover in the garage on and off for about 4 hours - engine was very hot.
Final go later today...on 3 turns out its very good, so if I cant find anything else thats what I'll leave it at and give the bike a good whizz around - do hundred miles on it and see if things settle down.
Edit:-
oh another thing....that foam breather filter at the bottom of the airbox...blimey that was just wet oily dust...it was horible.
Hmmmmm.. Ive just had a search around and it seems this is a very common problem with these carbs. It has to be floats. It has to be. haha. Well fuel levels in bowl..arrgh...I'll check that with a tube later.
Last Edit: June 21, 2013, 09:47:08 AM by z1100r
PatM
SOHC Member
Reply #21 on:
June 21, 2013, 10:13:42 AM »
Its a shame the float bowls are not glass or plastic! I remember in the 70's when NIKI carbs first came over here, in my Anglia 1500/1600 (the latter for the rich-kids!)- the Nikki was a good cheap substitute for the Webber 28/32 twin-choke and 1/3rd of the price.
Anyway, back to the bikes... Ill be interested to know how yours runs on 3 turns out (the Haynes says 2 1/2, Ive had mine set at that but di once have them at 1 1/2 and it ran poor) Ive a feeling mine will start bnetter as I treated it to a full fuel tank yesterday as it had passed it MOT- If that's the case and it does start better from cold- then again, Ill have to remove and empty the tank as I put a picture of my fuel filter on another page on this site last week- that's what it looked like 2 years ago when I first got the bike running- and Ill be doing the cam-chain and nuts/bolts dance around the garden.
z1100r
SOHC Member
Reply #22 on:
June 21, 2013, 11:52:55 AM »
Float height seems a controversial issue on the 350f and 400f. People that have taken carbs off bikes that have not been tampered with previously have all measured the float height to be 24mm using the exact method I use (Vernier caliper set to float height value and float just resting on spring tip but not compressing it). It was imposible to tell what they were originally because they were seized solid on these carbs. So far I've read about 3 people stripping std 350f previously unmolested carbs and finding float heights to be 24mm. I've also read about loads of problems with rich slow running from people who have rebuilt carbs and set them to 21mm.
So I'll set them to 24mm later and see...24mm so rings a bell, I sort of remember an issue like this in 1983'ish before I had a manual when i raced the 460. yeah 24mm..Thats right..!!!
Dan
SOHC Associate
Reply #23 on:
June 21, 2013, 08:23:38 PM »
I'm having a similar issue with my 400 - runs cleanly when cold but after the engine has warmed up it bogs down when you pull away, needs revving more than necessary to get moving but when the revs build up it pulls strongly and revs freely. If you shut off the throttle when riding along then open it again you can feel a hesitation, then the bike accelerates normally. I was going to have a play with the mixture screws and after reading this thread it looks like I may have to clean carbs again or check float heights. @ Z1100R - would value your opinion on this as you seem to have a good knowledge on the matter.
Last Edit: June 21, 2013, 08:31:00 PM by Dan
1994 GSXR750WR Endurance rep
1975 CB400F ongoing project
z1100r
SOHC Member
Reply #24 on:
June 24, 2013, 09:23:39 AM »
This is doing my swede. Those dammed carbs. I cant understand it, i've had them apart so many times now its stupid. There seems nothing wrong with them. The bike pulls and drives away absolutely perfectly when cold or warm but as soon as it gets hot the problem starts. The exact problem Dan and lots of others have.
What I cant fathom is that its all 4 carbs. Plug chopping the bike flat out and at all speeds the plugs are the most perfect light tan colour. Leave it ticking over though and they go sooty black.
There is one thing of concern and that is when the bike is hot an awful lot of steam comes out the breather. Way too much. So I pulled the airbox breather pipe off and left it dangling, things improved, but the steam was still pouring out. It suggests that there is blow past on the pistons and maybe i have a stuck ring or something, but this thing runs so smooth and doesn't smoke at all.
The air screws seem to have little effect past 2 turns out yet if if i screw them in to 1 turn the bike will stall. 3 turns or even 4 turns makes no difference. Normally twiddling an air screw makes the engine speed up or down.
I have to say its been getting better every day and it is now quite nice but its definately still there.
Floats are 24mm, airscrews are 3 turns. Number 2 carb does occasionally overflow. Its always number 2, the others are fine, so it looks like I'll have to re-examine no2.
Oh well more head scratching....hahaha
Greenbat
Newbie
Reply #25 on:
June 27, 2013, 01:16:46 AM »
Crikey, I'm just doing my carbs because mine has always had the same problem! I'd be interested to see how you fix it. I always thought it was just cruddy carbs and a dunstall decibel pipe.
People are saying two different float heights, 21mm and 24mm. Is it possible that 21mm is the height the fuel should be from the top of the float bowl, and 24mm is the height from the float bowl top to float bottom that should give that figure? Obviously the float bottom will be below the fuel level. Maybe over time the fuel soaks in, makes the floats sink and so you get a high level and richness.
You can see the actual height by attaching a clear pipe to the float bowl and holding the open end above the top of the bowl. The fuel in the pipe will be the same level as in the bowl, so you can measure it. Shouldn't be too hard, you've got drain screws in the bowls already.
CB350/400
What a Shame..!!
