CB750
Oil around the heads??
Topic: Oil around the heads?? (Read 5776 times)
exegete
April 13, 2006, 03:36:25 PM »
I have a 74 750k in the US (so it is gas, not petrol). It runs awesome but there has started to be oil showing on the front side of the heads, right near where the exhaust and plugs are. Is this normal? Or should I be looking for something?
Thanks!
JonnyB
Repeat: It's only a Hobby, It's only a Hobby....
Re:Oil around the heads??
April 14, 2006, 09:19:41 AM »
Is this where the head joins the cylnder or above, oil spreads like mad.
I had oil pouring from around the centre two plug holes, turned out I'd not refitted the two bolts for the cam cover that are inside the breather cover.
Regards and Ride Safe!!
Daily Ride - BMW K1200GT
Summer Fun - Naked K100
Current Project - GS500E
Basket Case - K100/1200 hybrid
John
https://batchscan.co.uk/
TieRBuoY
Newbie
May 19, 2006, 02:00:17 PM »
It could also be those little rubber disks that are mounted on the head under the cam assembly are passing/leaking.
CB750
