Author Topic: How do I Remove scratches from plastic lenses  (Read 5142 times)
Offline jojotut
« on: June 14, 2013, 10:27:45 AM »
H
Offline jojotut
Re: How do I Remove scratches from plastic lenses
« Reply #1 on: June 14, 2013, 10:30:58 AM »
Hi everyone, rebuilding the clocks on my K0, I have bought new faceplates and jewels but did not want to have new bodies and lenses. Anyone done this before? The lenses need cleaning inside and out whats the best method.
JOJOTUT
Offline sweetpeauk
« Reply #2 on: June 14, 2013, 02:15:37 PM »
I have done indicator lenses with plastic polishing compound and a soft mop. fantastic results but be very careful, to much pressure and the plastic melts and smears.
CB400F
CB400F2
RVF400
XT500D
CB900F2C
GS1000GT
XS1100E
Offline steff750
  • THE POWER OF DREAMS
« Reply #3 on: June 14, 2013, 02:58:11 PM »
 ;) try with any polish first(I used mr sheen of course)  or better still window cleaner,you will be surprised at the results ,mine was so bad that I thought they had cracks not scratches, but they came up real nice,you wont believe how  how much crap sticks inside them clocks over the years
Offline Rozabikes Tim
« Reply #4 on: June 14, 2013, 04:10:42 PM »
Used to use Brasso on watch lenses.
Offline neat street
« Reply #5 on: June 14, 2013, 11:02:39 PM »
hi, a lot depend on how bad they are!! if there not too bad then you can use a fine cutting compound like `T cut`Farecla G10, Festool 5,000 speedcut, with a felt attached to a drill (must be variable speed) use the drill at a very low speed so you don't build up any heat (make sure you use enough compound, and add some fine spray of water if it starts to dry out) and this should work out fine. ideally use a small 90mm polisher at speed 2-3, but most do not have access to these. If the scratches are bad, then you may have to use very fine abrasives first, 1,000g, 1,200g, 1500g. do some tests first on some plastic (acrylic glass) to get used to the speeds that would be ideal and feel the glass every so often to see how hot it gets (can get warm, but not hot), Hope this helps
CB500 1975
CB750F 1976
KLX250 1983
Lambretta SX200 1979
Mini Mayfair 1984
« Reply #6 on: June 15, 2013, 09:04:10 AM »
Try a nail buffer, or micromesh.
Den
Offline jojotut
« Reply #7 on: June 17, 2013, 01:09:19 PM »
Thanks lads
JOJOTUT
