Author Topic: Wiring Loom question ??  (Read 7054 times)
Offline cb750stu
« on: July 08, 2013, 01:19:32 AM »
Hi Folks i need to extend quite a bit of my wiring loom so i can fit all my electrical bits under my cafe seat,
I am away to order some different colour wire so what size and what amps do i need ie 15 amps 27 amps etc ???
Regards
1976 CB750 F1 SS in bits !!! but getting there
Re: Wiring Loom question ??
« Reply #1 on: July 08, 2013, 08:59:05 AM »
If yoou want to move the parts a long way you need to overspec the wiring size to stop voltage drops due to length especially on any wiring to battery or rectifier
Offline cb750stu
« Reply #2 on: July 08, 2013, 05:36:06 PM »
There not getting moved far just from standard position to under the seat maybe 10 " !!!!
« Reply #3 on: July 08, 2013, 06:24:48 PM »
Thats a long way in volt drop language mate
Offline cb750stu
« Reply #4 on: July 08, 2013, 08:40:03 PM »
Really ??
Any suggestions on what i should go for ??
Not much of a electrical guru im afraid,
« Reply #5 on: July 09, 2013, 08:27:21 AM »
Not sure what the original wire cross section size is but I would at least double it for that distance, and solder any connectors
Offline LesterPiglet
  • 1977 CB550F2
« Reply #6 on: July 09, 2013, 07:17:44 PM »
You can use a smaller guage wire these days compared to what was available in the 70's. I did a bit of research last year and promptly lost all my links.  :-\
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #7 on: July 09, 2013, 11:24:06 PM »
(For the 400F).... OEM Wiring is generally 30/0.2 strand PVC coloured cable. Modern vehicle wiring is thin wall 32/.2 (2mm 16.5A) strand hard PVC for better abrasion resistance, higher current rating, higher operating temperature and lighter weight (but not quite as flexible).
(the above words shamelessly copied from a very professional 400F rebuild blog)
(Me speaking...). The above 16.5A suggestion should be plenty for the typical loads on an old CB750 - assuming you're not loading it up with triple headlamps etc - 16.5A would be good for approaching 200W of power - (ie  more than your alternator output) - a single headlamp is typically 65W)
To get a working idea of wire rating simply sum the watts through your circuit, and divide by the voltage (12V) to get the current rating.... eg head + tail + stop + indicators might be 65W+5W+20W + 36W= 126Watts... /12 = just over 10Amps. (15A wiring good here)
Suggest you include a fuse, with a value (obviously) less than the wire amp rating.
And check your alternator output as I think it may be I the region of 13A (156W) - don't overload it!
http://www.autoelectricsupplies.co.uk/category/10
Cheers,
Lobo
« Last Edit: July 09, 2013, 11:32:54 PM by Lobo »
  • 1977 CB550F2
« Reply #8 on: July 09, 2013, 11:43:08 PM »
I'm useless with electrickery so I just chose a wire that had a rating a bit higher than the fuses in the bike. :)
Offline Green1
« Reply #9 on: July 09, 2013, 11:55:48 PM »
Your not the only one Lester I managed to blow the electric meter of the wall changing the living room lights  ???
Don,t ask me what I did I still don,t know  :-[
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Triumph tiger 800
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
Offline cb750stu
« Reply #10 on: July 10, 2013, 12:00:56 AM »
Cheers Folks for the answers !!!
Im not going to be running indicators or electric start so im not really doing much to the loom apart from not using a few bits and just making a few bits longer to reach under the seat,im not really looking forward to the wiring part at all im hopeless with diagrams etc i might have to get my Dad up to help hes good with that kind of stuff.
Thanks again
Stuart
PS If im not using the indicator wires etc do i just blank them off or cut them back ??
  • 1977 CB550F2
« Reply #11 on: July 10, 2013, 12:11:17 AM »
I would leave them in case you change your mind in the future.
Offline cb750stu
« Reply #12 on: July 10, 2013, 12:26:38 AM »
Good point Lester ill keep them !!!
