Author Topic: CB400F Rear Wheel Spacers..  (Read 6778 times)
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« on: July 17, 2013, 02:29:32 PM »
Hi,
There are 2 axle spacers either side of the rear wheel, one being slightly longer than the other.  The parts manual gives part numbers, but no clue to their respective lengths. Can anybody pls verify which side the longer piece goes..... I have my thoughts but want it verified.
Cheers,
Simon.
Offline steven400/4
Re: CB400F Rear Wheel Spacers..
« Reply #1 on: July 17, 2013, 04:56:15 PM »
i,m sure the long one goes sprocket side it sits in the seal
cb400f2 x7
honda ss 50
gsx 1400
Offline kent400
« Reply #2 on: July 17, 2013, 06:09:37 PM »
One spacer has a line machined around it, that goes the exhaust side so it follows the other one goes sprocket side.
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #3 on: July 17, 2013, 07:08:36 PM »
Aye carrumba! Conflicting answers.  Just by 'looking at it' I would have guessed the longer one (ie with machined line) goes against the sprocket - better clearances on the sprocket guard. Plus the torque arm (correctly orientated) appears to be better in line. But uncertain... Kent, is your info 100% certain?
Cheers gents, Simon
ka-ja
« Reply #4 on: July 17, 2013, 07:45:58 PM »
Hi,
     The cmsl parts drawing clearly shows the spacer with the groove round it is on the brake drum side----Ken
                                   http://www.cmsnl.com/honda-cb400f2-england_model14647/collar-rr-brake_42313369000/#.UeblpsWDhsU
Offline kent400
« Reply #5 on: July 17, 2013, 08:15:05 PM »
Lobo, had a look at my 400f  twice now! And that's how it is, the spacer with the grove around it is the brake back plate side.
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #6 on: July 17, 2013, 10:32:50 PM »
Gents,
Thanks for the speedy & helpful replies - Kent, apologies for doubting you!
Tomorrow, for the 3rd time will swap them. Bugger....
S
« Last Edit: July 17, 2013, 10:35:39 PM by Lobo »
