Author Topic: KN Air Filter  (Read 5966 times)
KN Air Filter
« on: August 02, 2013, 10:55:26 AM »
Hi All,
Looked on the search but had no luck.Just wondered what you all thought of them.Managed to get one cheap fitted it this morning went for a ride round and was surprised how good throttle response was after initial warm up.With the stock filter after a while used to get occasionally stumble when pulling away now no problem even at low revs in any gear pulls away real smooth.Does this sound to good?Your thoughts always appreciated.
Bitsa
Offline mick
Re: KN Air Filter
« Reply #1 on: August 02, 2013, 11:36:41 AM »
Hi Bitsa I have one on the shelf waiting to go in my bike , biggest advantage is you can clean them and reuse them  ;) cheers Mick.
Offline Waggles
Re: KN Air Filter
« Reply #2 on: August 12, 2013, 08:47:55 AM »
Don't have any experience personally Bitsa but it sounds about right. The K&Ns are less restrictive so when the vacuum in the inlet throat calls for more air it gets it more easily. With standard filter / inlet there is bound to be a bit of a lag while the air finds its way through the air box and filter. Would expect slightly more power too.
Only thing to check is the mixture. If more air gets in you may need more fuel to go with it. You could run lean. Am sure others can advise on that.
Re: KN Air Filter
« Reply #3 on: August 12, 2013, 11:31:25 AM »
Waggles
Like I said throttle response low to mid revs is mutch improved.I went for a good scream around Sunday and will look at the plugs tonight.
Bitsa
Offline Waggles
Re: KN Air Filter
« Reply #4 on: August 13, 2013, 07:34:10 AM »
Hold on. Think I am thinking of something else. I was thinking of the individual K&N filters ( one per carb ) but I notice you are speaking in the singular! Is this a straight replacement for the standard filter then? If so can you point me at it as it sounds rather spiffing 'specially if you can wash it ( tight wad Waggles  ;) )
My comments still hold though so will be interested to hear what yer plugs look like Bitsa
Offline steff750
  • THE POWER OF DREAMS
Re: KN Air Filter
« Reply #5 on: August 13, 2013, 11:44:38 AM »
 ;) yes K&N air filters  are much better than stock been using them for years, when you could pick em up for fiver each ,the original air box is very air restrictive anyway by all accounts  they sound nicer on my HM300 exhausts than on my HM341 more throaty and more of a howl, the HM341's are a lot more restricted noise wise and power anyway, we can thank good old USA legislation for that  ::) for best performance I would go for pod filters and a four into one exhaust if I was not to bothered about original spec
Re: KN Air Filter
« Reply #6 on: August 13, 2013, 06:59:51 PM »
Waggles
Yes its a replacement for the standard one not cheap anymore but as Mick says very servicable.Checked the plugs all ok.Will have another ride tommorrow as its still good weather here.Bought it on sleaze 30 quid I think.
Bitsa
Offline Waggles
Re: KN Air Filter
« Reply #7 on: August 14, 2013, 09:02:11 AM »
Bitsa,
Thanks for that, will see if I can find one as it sounds like something I should get and replace my standard one when its due. Might sound expensive but if it outlasts the original AND improves performance I want some! Not that I use all the performance I have anyway but a sweeter running bike is always a joy.
Off topic I know but I think my bike was happy this morning! ran a lot sweeter on the way to work! odd as I haven't touched anything! think she is just slowly coughing 25 years of inactivity out of her system!
Re: KN Air Filter
« Reply #8 on: August 15, 2013, 08:22:17 PM »
Waggles
Might be sounding my own trumpet but today out and about lots of slow revs in villages etc and really surprised thoroughly enjoyed every minute.
No hesitation smooth take off no stuttering came home real happy and a perfect tickover.
Did this to celebrate http://www.youtube.com/embed/NF80SbicjBE?rel=0
Bitsa
Offline LesterPiglet
  • 1977 CB550F2
Re: KN Air Filter
« Reply #9 on: August 16, 2013, 01:46:01 AM »
Offline bluemouse1006
Re: KN Air Filter
« Reply #10 on: August 16, 2013, 11:26:32 PM »
Any idea where I would get my Mitts on one of these filters ??
sounds like I need one in my life ha ha
Amos  :o
Amos
