Author Topic: Brake lever sponginess  (Read 10918 times)
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« on: August 07, 2013, 10:00:54 PM »
The front brake on my 400F is spongy versus my K2, where you can barely pull the lever before the pressure gets too much for further movement.
The 400 has new hoses, and has been bled, bled, bled... no bubbles / cloudiness... nothing but clear fluid.  And stiil, (with a lot of effort, granted) I can pull the lever back to the handlebar. MOT fail?
Would the master cylinder benefit a rebuild with new parts / seals to cure this?  I only ask because I have my doubts ... due the pressure does not 'leak away' as you hold the brake lever on. (and if the consensus is this... the DSS kit ok / recommended?)
Answers, suggestions please?  I can't believe the difference in my two old & very similar systems; I've got the two extremes.....
« Last Edit: August 08, 2013, 06:51:01 AM by Lobo »
Offline busa
  • busa
Re: Lobo
« Reply #1 on: August 07, 2013, 10:45:14 PM »
have you tried dead legging the leaver  (tying it back to the bars over night  and loosen cap on resovior
Offline tom400f
Re: Lobo
« Reply #2 on: August 07, 2013, 10:54:56 PM »
http://www.sohc.co.uk/index.php?topic=4812.msg22283#msg22283
I refurbished mine using the genuine kit from DSS
Does the master piston move freely or is all your effort going into not moving it much (is it seized?)
1978 CB400F2 Yellow
1997 VFR750FV Lapis Blue
2010 VFR800 A9 Silver
2013 Yamaha FZ8 Grey (Son's)
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
Re: Brake lever sponginess
« Reply #3 on: August 08, 2013, 06:56:29 AM »
Thanks guys.
Busa, nope, not tried that.... 'what' is that doing?  Return to work (abroad) today, but will try when I'm back in a couple of weeks.
Tom - thought you might have it, but then realised it 'pumps' (moves freely) fine when bleeding, with good fluid flow, so I don't think that's the cause.
Keep the thoughts coming!
Simon
« Last Edit: August 08, 2013, 07:24:30 AM by Lobo »
Offline LesterPiglet
  • 1977 CB550F2
Re: Lobo
« Reply #4 on: August 08, 2013, 11:39:32 AM »
It lets any micro-bubbles rise to the MC. I do it everytime I bleed my brakes and it does improve the pressure.
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #5 on: August 08, 2013, 03:12:32 PM »
Ta Lester, as I mentioned, will give this a try.
Does seem to be 'opposite' to what deep sea divers experience, ie bubbles forming (in their bloodstream) as the pressure reduces (the dreaded bends)... but who cares as long as it works!
Cheers,
Simon.
Offline busa
  • busa
« Reply #6 on: August 08, 2013, 06:25:30 PM »
Thanks lester.      I do this even with cars   its just make any air seep back up the pipe.
just a thought  have you tried bleeding it from the front brake light switch aswell.  or from the banjo at the master cylinder  this will also get an air lock  in it  and not go down the brake pipe..
or  reverse bleed it   open caliper bleed nipple  use a syringe and small bleed pipe,   drain  all fluid out  put new in from caliper end  but do not pull brake lever.   keep ya eye on fluid level  in master cylinder so as not to over flow.   squeeze fluid in slowly  once bubbles stop coming through the master.  leave syringe and pipe attached until you close the nipple.
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #7 on: August 09, 2013, 09:45:10 AM »
Thanks busa, like the idea of reverse bleeding, though have little intention of undoing mid-joints due the mess & awfulness of brake fluid!
You guys given me a couple of new possibilities - cheers!
Simon
Offline Dan
« Reply #8 on: August 14, 2013, 10:29:08 PM »
I had a similar problem with my old GSXR.
 Eventually, I found that the seals in the calipers were not allowing the pistons to slide freely. The pistons were moving to put pressure on the pads but the seals were flexing as the pistons moved and when the lever was released the seals pulled the pistons back. It took ages for me to find this but you could see the pads moving back when you looked closely. On strip down of the calipers, I found a resin-like build up - mainly around the seals and I the seal grooves.
Once cleaned out and reassembled with new seals I had a solid feel at the lever after about a minutes bleeding, whereas before I was bleeding the brakes for ages for no improvement.
If you haven't stripped your caliper for a while this may be worth checking if nothing else is working 👍
Dan
1994 GSXR750WR Endurance rep
1975 CB400F ongoing project
« Reply #9 on: August 14, 2013, 11:01:54 PM »
Dan, the seals are supposed to pull the pistons back, in fact that is all that gives pad/disc clearance
Offline fisjon
« Reply #10 on: August 15, 2013, 04:34:28 PM »
Hi Mate,
I posted about spongy levers a while ago and have pasted it below. Hope it helps. Ps Make sure that the little hole in the reservoir is not blocked. You can carefully poke it with a needle, (I did say carefully) to clear it out. the fluid must have a method of return and this little hole is it.
cheers
john
Hot tip for bleeding brakes after refitting pistons and seals!
Half fill reservoir and GENTLY pump fluid into system topping up as you go until it is obvious no more fluid required.
IMPORTANT Do not force the lever at any time as this will compress the air into the fluid, yes brake fluid will suck in air and it will become elastic.
Leave overnight. The weight of the fluid will want to go down and the air will want to come up. In the morning the air will be at the top of the system, and by GENTLY moving the brake lever in and out WITHOUT APPLYING FORCE you will see lots of bubbles rising into the reservoir. Do this for several minutes until the air bubbles stop rising. Leave for 15 minutes and then gently move the lever again to see if there is any more air. Repeat if necessary until no more bubbles.
The important thing about this process is not to apply pressure on the lever until the system has no air in it or you will compress the air into the fluid and this will give you a spongy lever.
Also you should avoid leaving the cap off the reservoir for long periods as air will ingress into the fluid merely under atmospheric pressure.
This method requires a little patience but beats the s--t out of spilling fluid over your nice clean bike!
Oh! One more thing, always use new fluid, if it has been in a can that has been opened for some time  it is useless.
Offline Dan
« Reply #11 on: August 15, 2013, 06:33:50 PM »
Bryan - agreed, but not to the point that you can't get a solid feel at the lever. And there shouldn't be crap built up around them from road contaminants, salt, etc.
After a caliper overhaul my similar problem with brakes was fixed and its an easy and inexpensive task if nothing else is working.
Dan
Offline Dan
« Reply #12 on: August 15, 2013, 06:54:17 PM »
The seals on my bike had so much crap built up around them that they were basically glued to the pistons and not allowing the pistons to move through them to compensate for pad wear.
You could bleed the brakes all day long (pointlessly 😤) but still have a spongy feeling at the lever because more travel was needed to get the pads against the disc.
This will probably turn out to not be your problem Lobo haha
Dan
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
Lobo
« Reply #13 on: August 16, 2013, 02:34:26 AM »
Hi gents: thanks.
The bike has just undergone a major rebuild, and whilst the m/c wasn't touched, the caliper was cleaned / repainted, as was the intermediate pressure switch junction, and all hoses / pipes renewed OEM.
It has been bled...and bloody bled... carefully, by the book, with nothing but fresh DOT 4. The posting above above is in opposition to previous ones... ie 'no pressure into the fluid.. leave overnight' versus maintain pressure overnight.... but all to no avail. (surely the 'no pressure / leave overnight' method is what we're doing 365 nights over the year? - ie the brake should tighten up with time?)
I can only see that I'm down to a master cylinder overhaul now; and am quite happy to spend that cash as everything else about the bike just about perfect. Will report back...!
Offline tom400f
« Reply #14 on: August 16, 2013, 09:19:18 AM »
Lobo
I did what you did (I assume you used a new seal in the caliper) plus (as stated earlier) the m/c overhaul kit. I used Earls hoses but I don't reckon that makes any difference. Will post pic later of my bleed technique. I'm pleased with the overall result (using EBC pads). Firm and effective (using four fingers as others have said).
Aside: took it for MOT last Sat. Apart from the general furore surrounding her the thing the test guy remarked on was the thickness of the disk!
1978 CB400F2 Yellow
