Author Topic: twin disc conversion  (Read 34567 times)
« on: August 23, 2013, 11:29:27 PM »
hi all,
 forgive me,but this is pick your expertise time,
I have a standard single disc setup,
I would like to go to twin discs,
can you advise me on the pitfalls,
I guess I shall need a new m/cylinder,caliper,caliper mount,2 bolts,disc,6 extra long disc bolts,hoses,flexi and pipe,
what about new rh fork leg? speedo drive?
are these available,source of parts?
thanks all,
John
Offline Ewan 500 K1
  • jings crivens help ma boab
    • Adams Bros Probe 2001
Re: twin disc conversion
« Reply #1 on: August 23, 2013, 11:44:34 PM »
500K1 basket case for later
« Reply #2 on: August 24, 2013, 12:24:24 PM »
John, helps if you say what bike mate
« Reply #3 on: August 24, 2013, 09:12:57 PM »
the bike in my profile pic,
 1974  M reg K1 Cb500-4
thanks
John
« Reply #4 on: August 25, 2013, 08:40:06 AM »
In that case you will need the slider from a 550 or a PAIR of forks from a 550 (internals vary so fitting just one complete fork is not advisable) plus if you look at the other thread on twin discs I linked a word document with a How To.
Always worth putting in what bike mate as avatars don't always show up
« Reply #5 on: August 25, 2013, 09:05:31 AM »
Put your bike in your signature. Simples…
Steve
Offline Ewan 500 K1
« Reply #6 on: August 25, 2013, 05:48:25 PM »
hopefuly my pain and agony and oddjob's and bryan's comments in my post at http://www.sohc.co.uk/index.php?topic=5571.0  are helpiing .. hopefully not confusing or putting you off have a go yersel John  ???
Offline matthewmosse
« Reply #7 on: August 25, 2013, 10:29:03 PM »
I was under the inpression that 550 forks were slightly longer than 500 ones - they'll swop over as a set so that is ok. Where I am puzzuled is my 500 has capacity to carry twin disks but as far as I know it has 500 forks. One to worry about when I recommission the sidecar outfit.
« Reply #8 on: August 26, 2013, 07:11:07 AM »
500 never had twin disc capacity so it must have had as a minimum a 550 slider but more likely 550 forks
« Reply #9 on: August 26, 2013, 12:04:40 PM »
 thank you Ewan,and all of the posters,it seems that i need a 550 front forks first,then lots of bits -)))) ;D
I will explore the availability and cost,
thanks all
« Reply #10 on: August 26, 2013, 07:32:33 PM »
Thanks Bryanj,  I downloaded your instructions,and am sourcing parts,are 550 fork tubes the same Diameter as the 500,and will they
fit my original yokes?can I just swap the 550 sliders onto my forklegs and internals?
thanks for your help,
all of you
back to feebay to explore more ;D
« Reply #11 on: August 27, 2013, 06:59:24 AM »
You can fit either complete forks as a pair or just the sliders if your tubes are good, I think going back 30 year i only fitted the one slider but memories can be wrong
« Reply #12 on: August 28, 2013, 11:22:22 PM »
looking at parts
 disc  £35
 caliper and bracket £90
master cylinder £35 + brake light switch £15
hose etc £40
forks £90
HT bolts FOC  I hope
plus odds and sods,new seals ,bolts etc
that should be about that,
also new set of tyres about £160
jezzzzz
september is going to be expensive,and petrol at £1,37.9 a litre !!
I shall let you know what happens
Offline Ewan 500 K1
« Reply #14 on: August 29, 2013, 07:53:16 AM »
thanks Ewan,
 I saw the Master cylinder,but decided I wanted the older round resevior type,like
http://www.davidsilverspares.co.uk/GL1000K2-GOLDWING-1977/part_126548/
the caliper and bracket  are
http://www.ebay.co.uk/itm/Honda-cb-550-four-brake-caliper-1977-/271228605178
the forks look a better bethttp://www.ebay.co.uk/itm/Honda-cb-550-four-forks-1977-/271228589227
http://www.ebay.co.uk/itm/Honda-CB500-CB-500-Four-4-Brake-Disk-/350845499406
and this disc
